List users from command line?
cwsonline
Post by cwsonline »
What is an simple way to dump all the users from the command line? I have used >listerm in the past but this will only show users that have assigned equipment. I've used >ednump and >cuser to pull out the users that way but for scripting purposes I would like to keep it to a simple command or query from the command line. I have also looked into using a ctree module from Perl but I have had trouble getting a perl interpreter to run well on the OXE. Any ideas would be apprecitated.
sadim
Post by sadim »
Try the command
strings /usr3/mao/PHONEBM.dat
instance of strings, you can user other cmds like grep to filter the information and have other output layout
mgoegel
Post by mgoegel »
much better:
edsbr <return>
dir <return>
name <return>
type <return>
go <return>
bye <return>
cwsonline
Post by cwsonline »
Thank you. That has given me some good ideas. Instead of using the Phone Book table I used the POSTE table to look at only the local users. We have large networks here and I wanted to only see the local users. I am looking at something like:
strings /usr3/mao/POSTEM.idx | grep -E '^[[:digit:]]' | sort | uniq
I found that using POSTEM.dat didn't give an 'up-to-the-moment' view of the users. I do end up with a couple garbage characters at the end of my extension numbers but I can remove those easily in my script. This also includes my hunt group number but isn't a problem. Thank you for the ideas!
andi
Post by andi »
How about using the ippstat tool?
You can start it without any argument or list some arguments with "ippstat ?" in the CLI. ippstat is imho a very powerfull tool.
best regards
ippstat --help will give you some help if you want to use command line only
MasterB
Re: List users from command line?
Post by MasterB »
Hey,
try some comments with list*
lata
Post by lata »
I use command
> ednump
> dir
> mean
> go
which prints out all numbers with its information
BR Lata
Return to “Usefull commands”
