OXE 4400 Caller ID
HSilva_383
OXE 4400 Caller ID
Post by HSilva_383 »
Hi Guys, OXE is not able to get Caller ID, I have the following environment:
OXE 4400
Software Version Name: R8.0.1
Patch Version: 17
PCM R2
Trunk Type: R2/MFC
Line Signaling: PCM Q421.
I have the following trace:
'I5,A1,I5,A1,I5,A1,I0,A5,I2,A3,I2,B1,'
From the above I can see that OXE request the Called ID then request ONLY the first digit Caller ID then change to A3 (End Of Dialing & Wait B Signal).
Any ideias???
Herbert Silva
alex
Post by alex »
1st, check this thread Caller-ID-For-DID. A lot been discussed there.
HSilva_383
Hi Alex, thanks for reply, but I have already tried that thread but didn´t work (solution on that thread was "Caller Identification For Gr.II
II-7 put to "1" ).
Thanks again,
Herbert Silva
alex
Post by alex »
OK then.
So first attach you R2 trunk category here.
HSilva_383
Ok Alex, here it goes:
x
x Instance (reserved) : 1 x
x Trunk COS : 28 x
x x
x Connection COS : 5 x
x Trunk Type + R2/MFC x
x Signaling Type + R2 Q441 x
x Waiting Guide + True x
x Overflow Timer on No Answer : 300 x
x Overflow Timer on Waiting : 300 x
x x
x R2 Trunk x
x x
x Voice Guide - Busy Cd party : 22 x
x Voice Guide - Inacc. Cd party : 17 x
x Voice Guide - Wrong Number : 210 x
x Congestion Voice Guide : 136 x
x Register Signaling + Compelled x
x Line Signaling + PCM Q421 x
x Exchange Type + W48
x Line Type + Short line x
x 2- or 4-Wire Voice + 2-Wire x
x Short Pulse Duration (x10ms) : 15 x
x Long Pulse Duration (x10ms) : 60 x
x x
x NDDI R2 Trunk x
x x
x Outgoing Seizure Acknowledgment + One Status Change x
x Seizure Acknowledgment Timer : 20 x
x Dial Tone Detection + False x
x Default Transmission + False x
x Default Transmission Delay : 0 x
x Wait for Called Party Answer + True x
x Wait for Called Answer Timer : 1200 x
x Charging on Answer + False x
x Release Method + Non-compelled Control x
x Wait for Called Re-Answer Timer : 900 x
x Special Tones Receiving + False x
x T.for Compelling MF R2 Signals : 250 x
x Max.Tim.Without Send Signals : 250
Max.Duration Of Pulse : 5 x
x PCX Call No. : -------------- x
x No. Of Digits In Partial Identif. : 4 x
x x
x NDDI R2 Group I Signals x
x x
x Caller (User) COS + Not used x
x Request Not Accepted + R2AV F12 x
x End Of Caller Identification + R2AV F15 x
x End Of Called Party Dialing + Not used x
x x
x NDDI R2 Group II Signals x
x x
x Subscriber Without Priority + R2AV F1 x
x Attendant + R2AV F1 x
x Data Transmission + R2AV F6 x
x x
x NDDI R2 Group A Signals x
x x
x Send Next Digit Called Party + A-1
x Send Digit N-1 (next-to-last) + A-9 x
x End Of Dialing & Wait B Signal + A-3 x
x Congestion + A-4 x
x Caller COS Request + Not used x
x Complete Dialing & Conversation + Not used x
x Send 2nd from last Digit (n-2) + A-7 x
x Send 3rd from last digit (n-3) + A-8 x
x Send First Digit + A-2 x
x Send Last Digit + Not used x
x Complete Caller Identification + Not used x
x Partial Caller Identification + Not used x
x Send Next Digit Caller + A-5 x
x Wrong Called Number + Not used x
x x
x NDDI R2 Group B Signals x
x x
x B-1 + Called Party Free Charged x
x B-2 + Called Party Busy x
x B-3 + Called Party Inaccessible x
x B-4 + Congestion
B-5 + Called Party Free Charged x
x B-6 + Called Party Free Charged x
x B-7 + Wrong Called Number x
x B-8 + Called Party Inaccessible x
x B-9 + Called Party Inaccessible x
x B-10 + Called Party Inaccessible x
x B-11 + Congestion x
x B-12 + Congestion x
x B-13 + Congestion x
x B-14 + Congestion x
x B-15 + Congestion x
x x
x DID R2 Trunk x
x x
x Incoming Seizure Acknowledgment + One Status Change x
x Delay Before Sending Seizure Ack : 2 x
x Dial Tone Connection + False x
x Number of Digits Received : 0 x
x Number of Digits Used : 4 x
x Routing to Attendant + Not used
x Open Dialing + True x
x Ringback Tone Connection + True x
x Time Before Send Ringback Tone : 5 x
x Forced Release + False x
x Forced Release Timer : 0 x
x Send Called Party Answer + True x
x Wait for Called Re-Answer Timer : 0 x
x Barge-in On Busy Cd party + False x
x Barge-in On Cd party Hang Up + False x
x Groupe B Signal Transmission + True x
x Caller Identification + After Last Digit Cd Number x
x Time Before 1st Digit Detection : 1 x
x Delay Between Digits on Receiving : 250 x
x Time Wait.For Group II Signal : 250 x
x Pulse Transmission Duration : 2 x
x Compelling Timer : 40 x
x x
x DID R2 Group I Signals x
x
x x
x Request Not Accepted + I-12 x
x End Of Caller Identification + I-15 x
x x
x DID R2 Group II Signals x
x x
x II-1 + Normal Routing x
x II-2 + Normal Routing x
x II-3 + Normal Routing x
x II-4 + Normal Routing x
x II-5 + Normal Routing x
x II-6 + Data Routing x
x II-7 + Normal Routing x
x II-8 + Data Routing x
x II-9 + Normal Routing x
x II-10 + Normal Routing x
x II-11 + No routing x
x II-12 + No routing x
x II-13 + No routing x
x II-14 + No routing x
x II-15 + No routing x
x x
x Caller Identification For Gr.II x
x x
x II-1 : 1 x
x II-2 : 0 x
x II-3 : 0 x
x II-4 : 0 x
x II-5 : 1 x
x II-6 : 0 x
x II-7 : 0 x
x II-8 : 0 x
x II-9 : 0 x
x II-10 : 0 x
x II-11 : 0 x
x II-12 : 0 x
x II-13 : 0 x
x II-14 : 0 x
x II-15 : 0 x
x x
x x
x DID R2 Group A Signals x
x x
x Send Next Digit Called Party + R2AR F1 x
x End Of Dialing & Wait B Signal + R2AR F3 x
x Congestion + R2AR F4 x
x Gr.I or Gr.II Signal Not Receiv. + R2AR F4 x
x Caller COS Request + R2AR F5 x
x Caller Identification + R2AR F5 x
x Send Next Digit Caller + R2AR F5 x
x Complete Dialing & Conversation + R2AR F6 x
x x
x DID R2 Group B Signals x
x x
x Cd Party Free Malicious Call Ctrl + Not used x
x Specific Tone Sent To Caller + R2AR F2 x
x Called Party Busy + R2AR F2 x
x Congestion After Change in Gr.B + R2AR F4 x
x Wrong Called Number + R2AR F7 x
x Called Party Free Charged + R2AR F1 x
x Called Party Free Not Charged + R2AR F1 x
x Out Of Service User Line + R2AR F3 x
x Toll Free Call + Not used x
x Collect Calls Restriction + Not used x
HSilva_383
Hi guys, I´d like to know what command could I execute to get a complete trace for the environment described in the first post.
alex
Post by alex »
Strange but i just noticed your reply.
To requesr ANI you need to set this parameter in R2 category to 1.
[B]DID R2 Trunk
II-2 : 1[/B]
HSilva_383
Holly shit man, it worked like a magic, thank you very much!!!!!
Return to “System”
