Using OXO release 4 over WAN connection
prewest
Post by prewest »
i`ve got several OXO`s that we would like te manage over IP,
from release 5 through 7 it works perfectly after i forward port 443.
but on release 4 and below i can`t get it to work with only port 443.
i`ve also tried forwarding port 30020/30021TCP but without any succes.
the gateway that is set in the OXO is OK.
does anyone here know the corrects ports i need to forward to communicate with the OXO? or is this not possible on release 4 and below?
enio.eltz
Post by enio.eltz »
R4 doesn't use port 443. R4 uses ports 30021, 31000 to 31002 in FTP mode. I've tried to do it too, but it hasn't worked. It doesn't work.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
prewest
Post by prewest »
mmm to bad..
krzysioD
Post by krzysioD »
magic keyword: VPN !
prewest
Post by prewest »
and then what? replace all my customers routers that support VPN??!
no thanks..
and not all routers are managed by us...
PuGZopf
Post by PuGZopf »
HI,
Alcatel OmniPCX Office configuration flow (FTP mode)
Protocol IP sources Ports sources IP destinations Ports destinations
TCP PC IP@ * CPU IP@ 30021
TCP CPU IP@ 30021 PC IP@ *
TCP PC IP@ * CPU IP@ 31000 to31002
TCP CPU IP@ 31000 to 31002 PC IP@ *
thats seems right.
IS FTP blocked on the router?
gharekhy
Re: Using OXO release 4 over WAN connection
Post by gharekhy »
ISP uses NAT for WAN connection.? My ISP (Bell Sympatico) uses NAT on the WAN connection that connects me to the Internet. ( I assume to share public IP addresses between multiple subscribers) My Internal LAN uses the 192.168.0.0/24 subnet, and my router uses the 192.168.2.0/24 subnet as its WAN connection. My external IP address reads as a public IP address from websites.
selectip
Post by selectip »
Hi all,
I saw this subject and I will be really pleased if somebody could help me because I'm really going mad with maintenance over IP.
I install my pabx (R7 version) with:
On PABX: IP: 192.168.0.246 / Router: 192.0168.0.1
If I connect on PABX with PM5 on lan it works well.
Now I want to log on on the same PABX but from Internet.
So in my router, I use NAT to forward port 443 to 192.168.0.246
I use omc 8 with my external address but no chance, it does not work.
Any idea?
Thanks in advance
enio.eltz
Post by enio.eltz »
Is 192.168.0.1 (oxo default gateway) the router LAN port?
If yes, your settings seems right. You can have a problem with the router. You can have a conflict of ports. Microsoft Exchnage web app uses the same port.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
selectip
Post by selectip »
Thx for answer but:
No because I test on 2 different sites with 2 different routers. I'm going mad. any idea please?
Return to “Networking”
