Public Network COS config
ShaneF
Post by ShaneF »
Hi people :-)
Our switch (OXE 4400) currently has bars in place for '09' prefix numbers.
If I want to enable a Public Network COS (3) to be able to use it, what things do I need to configure?
I have the 4400 documentation, but for some reason the section on call barring is missing...
knightr1der
Post by knightr1der »
you will need to go in to:
/Translator/External Numbering Scheme/NUmbering discriminator/0 public/discriminator rule - locate the 'call number' 09 and see what 'numbering area has been assigned to it. e.g. 9
Then go to:
/Categories/Access Category/3/public access category/9 and allow the access right for 'day' 'night' etc.. as appropriate
HTH
ShaneF
Post by ShaneF »
Hi, thanks for that...
I dont have the Categories branch available though...
Shane
p.s: btw, we're on R6.0
knightr1der
Oh, I think thats called 'Class of service' instead of category in that case
ShaneF
Post by ShaneF »
Hey,
I thought as much and checked that, but looked fine.
I just had a brainwave though and thought to check their hunt group, and the setting is there too!
Changed that and all worked fine...
knightr1der
Hunt Group!!! I always forget that one! Good brainwave!
If you want, I'm pretty sure you can set that value to 255 in the hunt group and then the system would use the users setting. Useful if different members of the group need different access levels.
Return to “GENERAL”
