does anyone have seen this?
Konstantinos.E
Post by Konstantinos.E »
hello there!
does anyone seen and expirence this vh rack?
My problem is that the customer want on the fly accounting for external aplication through v24 but it seems that no serial port is working...the only port that it seems is working is the one for dialup modem for remote support.
My question is does anyone know how to configure as printer one serial port from all this serial ports on this rack ?
thanks!
Alca_holic
Eliott
Re: does anyone have seen this?
Post by Eliott »
There were some restrictions for the port. I think B was working only without problems. Why do you are not moving the remote access to another port or IP?
Return to “Shelf”
