6.2 installation problem on Vmware
arminas
Post by arminas »
is it possible to install 6.2 on VM ? i can install all versions but 6.2 like this http://slimphony.blogspot.com/
thanks for help.
I've installed R 6.2 without any trouble on VM.
Check the integrity of your software before trying again, maybe is damaged.
Regards.
arminas
Post by arminas »
ok , changed my network adapter settings on VM and used host only problem solved
thanks
finaluser
Re: 6.2 installation problem on Vmware
Post by finaluser »
arminas wrote:Hi,
thanks for help.
I already install 6.2, 7.0 and 7.1 version with the instructions of slimphony (including mac spoofing) and all installations works fine.
finaluser
Return to “Other”
