oa512 and gated
stunshot
oa512 and gated
Post by stunshot »
Hi, I am trying to use the gated config on legacy 512 switches, have loaded the file but do not know how to activate it so I can run RIP v2. I believe you need to configure some sort of external text file ?? Any info appreciated, I am familiar with these devices but have never had to do this.
vanderzandes
Re: oa512 and gated
Post by vanderzandes »
I am also trying to dig up some info. Have an example of the gated.conf text file for a OA512 that is running RIP.
I didn't create the text file and have been unable to dig-up the Advanced Routing Guide for the OA512.
I'm trying to find more info on the require syntax for gated.conf.
#Turn RIP on all interfaces; ripout required for pt-pt connections
rip yes {
interface all version 2 ripout;
#Set default gateway
static {
default gateway 10.10.100.145 retain;
#Export routes into RIP
export proto rip {
proto static {
all metric 1;
proto direct {
all metric 1;
proto rip {
all metric 1;
proto kernel {
all metric 1;
Return to “Legacy Devices (OS4024, XOS, OmniCore)”
