Forwarding Alert Voiceguide
dizfunkshinal
Post by dizfunkshinal »
Hi all!
I have a question that may be a feature request rather than a how-to. On an OXE with a 40X8 with forwarding to another extension/number you get a voice guide alert when you pick up the handset that says, "Your calls are being forwarded..."
However, if you are utilizing the Forward to Text feature while this feature is enabled there is no voice guide that alerts you that forwarding is turned on.
Has anyone come across this with a way to enable this voice guide while the Forward to Text option is engaged?
Thanks, as always for the valuable collective of knowledge that this board provides
Cliff
nperalta
Re: Forwarding Alert Voiceguide
Post by nperalta »
no, only a visual alert is displayed up to the right a rotating shaft, select the shaft and desviation off.
bye
Return to “System”
