Hello everybody,
I have an OXE R9.1 with some 4037 sets.
Audio quality is very bad and sometimes IP phone resets.
That's why i would like to know if 4037 set is always supported with R9.1 ?
If yes, could someone tell me how to check TSCIP version currently used.
Thanks in advance for your time.
Olivier
4037 IP Phone with R9.1
Re: 4037 IP Phone with R9.1
Sure it is supported in R9.1.olhu67 wrote:... i would like to know if 4037 set is always supported with R9.1 ?
"ippstat" is very useful command. Check menu 14 - Ip Phone download menu.olhu67 wrote:... could someone tell me how to check TSCIP version currently used.
olhu67
Many thanks alex.
Did you know where and how i can found the reset cause of such kind of sets ? Using incvisu i saw nothing for 4037 sets. Is there something similar as for IP touch sets ("Ip touch reset cause" using ippstat) ?
Thanks for your help.
"telnet" to eReflex, and run "defense 99" command.It shows last 100 resets reasons.olhu67 wrote:Is there something similar as for IP touch sets ("Ip touch reset cause" using ippstat) ?
