Cannot call Xlite SIP softphone from extensions
enrique.man
Post by enrique.man »
Hello guys,
I am trying to configure the Xlite v4 with Alcatel OXE , the sip softphone is registered and can call any users, but when making a call from extension to sip softphone it fails.
Also, when trying to make a external call using public trunks from sip softphone it fails.
Hope somebody can help.
Enrique
Re: Cannot call Xlite SIP softphone from extensions
Check with SIP trace.
But usually mane problem with codecs - if in Xlite absent codec G729.
Solution - OXE - IP/IP domain - item Extra-domain compression=without compression (will be used codec G711).
bigmac
Post by bigmac »
try zoiper (another free softphone) and see if you still have an issue with this. Also see attached this will help with how to perform traces outlined by VAD as well as some other basics
tg0042-ed.01 session initiation protocol_en.pdf
enrique.man
Hello Guys,
Thanks for the info, Vad, i configured on the OXE as you mentioned the Solution - OXE - IP/IP domain - item Extra-domain compression=without compression (will be used codec G711) but didnt work neither, i enabled all codecs in the Xlite v4 but never saw codec G729.
Bigmac, i will try the zoiper softphone you mentioned and thanks for the troubleshooting guide, i will follow it to see if i see any errors with Xlite too.
Any other ideas why xlite v4 doesnt work?
Enrique
Codec...
Check your logs on SIP traces
enrique.man
Hi Cavagnaro,
Thanks for the info, checking the logs at the moment, BTW Cavagnaro, after configuring the SIP softphone , should i be able to dial external numbers using the trunk groups configured on the OXE?
Enrique
alex
Post by alex »
cavagnaro wrote:Codec...
Yeah. Good point.
First check the problem and only after you find the cause of this problem you can start playing with the configuration.
Remember the NTARS rule.
With Xlite SW it is an ald and long story - every new version of it has problems connecting with OXE.
Zoiper is much better - I've never had a problem connecting it to OXE.
enrique.man wrote:, should i be able to dial external numbers using the trunk groups configured on the OXE?
Yes, you should as long as the public category of the trunk allows it.
enrique.man
Hi Cavagnaro, Alex,
Thanks for the info, i just install the zoiper...but still get the same situation..i can call from sip softphone , but when calling him to extension it doesnt ring.
I just did the trace, restarted the sip motor and still doesnt work. It seems that the call never establishes, got cac:false and autoanswer:false.
Attached the trace.
mtracer started ...
(265650:000001) MTRACER host (172.31.1.21, cpua), version: R9.1-i1.605-16-c-ln-c
82
(265650:000001) MTRACER num: 002, time: 2005/05/30 05:39:26, loss: 0%
(265693:000003) event_init_screen_mem : line 1 tscreen '
(265693:000004) MEVO : update_type_of_set neqt 919
(265693:000005) INIT MEVO : uti_inidcom init mevo neqt 919
(265696:000010) event_init_screen_mem : line 1 tscreen '1
(265698:000013) event_init_screen_mem : line 1 tscreen '17
(265701:000016) event_init_screen_mem : line 1 tscreen '171
(265701:000017) MEVO : sauve_num_in_bis numero_demande 1717
(265701:000018) MEVO : rend_mcdu_mevo indice 255,nulog 2
(265701:000019) MEVO : rend_categorie_mevo cat=1
(265701:000020) MEVO: aplourv index of mevo is -1
(265701:000021) modifIfRemoteExtGhostZ-->neqt1=919
(265701:000023) event_init_screen_mem : line 1 tscreen '
(265701:000024) neqttouc neqt=920 nekip=920 toucacod=1
(265701:000025) neqttouc result=1000398 en Hexa !!!
(265701:000026) MEVO : update_type_of_set neqt 920
(265701:000027) INIT MEVO : uti_inidcom init mevo neqt 920
(265701:000028) Function identite_chambre_ou_client cas CDHva36930 ???
(265701:000029) decauto_possible catexploit result=1 neqt=920
(265701:000030) en_face_de_rsvp_decauto result 0
(265701:000031) en_face_de_sympac_decauto result 0
(265701:000032) en_face_de_dtmfserver_decauto result 0
(265701:000033) decauto_possible catexploit result=1 neqt=920
(265701:000034) en_face_de_rsvp_decauto result 0
(265701:000035) en_face_de_sympac_decauto result 0
(265701:000036) en_face_de_dtmfserver_decauto result 0
(265701:000037) event_init_screen_mem : line 1 tscreen '1717
(265701:000038) MEVO ENREG : dcom_en_conf_ou_enreg Result 0, neqt 919 pttrav_sta
t->neqt 920
(265701:000039) MEVO : rend_mcdu_mevo indice 255,nulog 2
(265701:000040) MEVO DEPOT : depot_mes_possi Result 0
(265701:000044) +------------------------------------------------------------+
(265701:000045) | Message sent UA (neqt : 920-1) ----> SIP
(265701:000046) | INVITE : 1717@172.31.1.10:5060 ; user=phone
(265701:000047) | From : <Robocop> 5602@172.31.1.21:5060 ; user=phone
(265701:000048) | To : <Sip Test> 1717@172.31.1.21:5060 ; user=phone
(265701:000049) +------------------------------------------------------------+
(265701:000050) | SDP :
(265701:000051) | @IP:port = 172.31.1.30:32514
(265701:000052) | ALGOS :
(265701:000053) | G729
(265701:000054) | DTMF : 97
(265701:000055) | DIRECTION : SEND & RECEIVE
(265701:000056) | cac : false
(265701:000057) | autoAnswer : false
(265701:000058) +------------------------------------------------------------+
(265701:000059) SIP : Global_get_mcdu, in dico
(265730:000060) event_init_screen_mem : line 1 tscreen 'Sip Test
(265782:000062) +------------------------------------------------------------+
(265782:000063) | Message received SIP ----> UA (neqt : 920-1)
(265782:000064) | Request Failure 408
(265782:000065) | RELATIVE REQUEST : INVITE
(265782:000066) +------------------------------------------------------------+
(265782:000067) event_init_screen_mem : line 1 tscreen 'Robocop
(265782:000068) event_init_screen_mem : line 1 tscreen 'Sip Test
(265782:000073) event_init_screen_mem : line 1 tscreen 'Robocop
(265782:000074) event_init_screen_mem : line 1 tscreen 'Robocop
(265812:000075) event_init_screen_mem : line 1 tscreen 'Por favor, cuelgue
(265812:000078) message_enregistrement() box_state=1 ML_NOT_MSG=6
(265812:000079) message_enregistrement() mess_enreg=0 autre_mess=1
(266162:000089) INIT MEVO : uti_inidcom init mevo neqt 567
(266183:000096) INIT MEVO : uti_inidcom init mevo neqt 597
(266183:000098) INIT MEVO : uti_inidcom init mevo neqt 567
(266183:000100) INIT MEVO : uti_inidcom init mevo neqt 568
(266183:000102) INIT MEVO : uti_inidcom init mevo neqt 519
Enrique
murraya
Post by murraya »
hI, you seem to be offering G729, is the SIP phone capable of this? try setting the call as G711.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Return to “SIP”
