Impossible import file with Actis
Alcatel Configuration Tool for International Sales -all ACTIS related topics, how-to's, tips and tricks.
hawai50
Post by hawai50 »
Hi;
After backup OPS files in OXE, I try import with Actis .zip and I have the next mistake: Invalid file not a PKzip file.
Any idea ??
Thanks in advance
Puno
Re: Impossible import file with Actis
Post by Puno »
You need to test integrity of archive by any program 7-Zip, Winrar etc.
Maybe you download OPS via FTP in non-binary mode?
In may practice was the same case - solution was (not sure that you have the same case) unzip with 7-Zip (with error) and create zip file again.
hawai50
Post by hawai50 »
Thanks VAD.
Solved with the same process that you.
nader_39
Post by nader_39 »
vad wrote:In may practice was the same case - solution was (not sure that you have the same case) unzip with 7-Zip (with error) and create zip file again.
I try this but not work with me any idia
Return to “Actis”
