standby server log 0422 error
thkim81
Post by thkim81 »
Dear All
I operator call center.
Standby server was mastercopy.
then Standby server log is indicate below.
0422=IP_LINK Incident: Reference Media Gateway is not declared
Incident number (q to quit):0422
INCIDENT NUMBER: 422
OBJECT CLASS: Dhs3Board
EVENT TYPE: ProcessingErrorAlarm (10)
PROBABLE CAUSE: Unknown (0)
SEVERITY: Indeterminate
"IP_LINK Incident: Reference Media Gateway is not declared"
"IP link process error"
"Reference Media Gateway is not declared"
"No system reaction"
"If the fault persists, note the incident with all its information"
"on an observation sheet (problem report), specifying the error context"
"as much as possible.";
this means link is broaken. Is that right?
If that is not, what does that mean?
pls answer the problem
thnak you.
tincho.rn
Re: standby server log 0422 error
Post by tincho.rn »
You have to decalred the reference MG, in mgr-->shelf , choose the MG you want a reference. This is usefull in a duplicate configuration. The server who reach the reference MG, is consider the MAIN server. Regards.
Return to “System”
