redial problem
jyotimajumder
redial problem
Dear All,
Redial feature is not on PRI trunk group, where it is working with analog PSTN line
PRI is in prefix '0' with professional trk group with overlapping
Analog PSTN line in prefix '529' with professional trunk seize
pls. help me
pls. help me
Re: redial problem
May be u need to enter a TG prefix in external call back translator or other parameter in Specific telephone sevices ISDN redial parameter, try this two and let us know...
cheers...
cheers...
ACSE Business R.9.x
Re: redial problem
Redial not work - you dial 0+number, finish call, off-hook handset and after press key "Redial" - and what?
jyotimajumder
Re: redial problem
Hi Vad,
display of the digital phones only shows the last dialled number, but dont dial out.
jyotimajumder
Re: redial problem
sera544 wrote:Hi,
cheers...
Added tg prefix in both external call back transtor(created in system i.e.BEF,DEF) but no result,there is nothing like other parameters in specific telephone services.in specific telephone services i am getting three redial options, they are
1.redial internal calls
2.Redial Lost on ua sets
3.Redial list of NOE sets.
three points are true, but the redial problem is happening..
Re: redial problem
digital phone - what type?
F.e. if UA (4020, 4035...) and you have "redial list on UA=yes" - you press "redial", see numbers (up to 8 ) and can select (with "+" and "-" keys), press "redial" (or "Ok") again.
jyotimajumder
Re: redial problem
fromm all types of extension the problem is happening, when i am pressing redial from the 4029 set and ok display shows the number ?vad wrote:digital phone - what type?
doesnot dial..
Re: redial problem
what SW release in your PBX?
When you see number - if you wait 5 sec or press # - number redialed or not?
jyotimajumder
Re: redial problem
system release 8.0vad wrote:what SW release in your PBX?
Re: redial problem
R8 - not enough - show exactly f.e. G1.302.11
And what about my question - if you wait 5 sec or press # - number redialed or not?
