Timed out: 4760
balaia
Timed out: 4760
Post by balaia »
Im a newbie but we ware trying to conect to the Omnivista 4760 webclient and the follow message appears:
Timed out: 4760 server could not verify license corresponding to the declaration node; too much time has elapsed.
Can some one help me pls
King regards
huntsman
Re: Timed out: 4760
Post by huntsman »
Your license loaded onto the 4760 server will have a declaration node that it looks at to verify that you have paid for the product. You have 30 days from the installation of the server to sycronize to this OXE with the matching CPU id. If you connect using your client, you can go to Help, About and this will list the CPU id of the declaration node at the bottom of the window.
You may have to reboot the server as some of the servers will have stopped, and then ensure that you syncronize to the OXE that is the declaration node.
Return to “4760”
