Backup voicemail
Backup voicemail
Login to the voicemail system
Give an IP address to the system
Setup the backup on the system (go to backup then for ex:
BACKUP, Y, 1, 64 )
ftp to the system as mtcl
hash
bin
prompt
get sbr.sbz
you can go to the backup menu on the system while doing this to check status
ftp file should be != than 0 , of course
Return to “Voicemail (46x5)”
