SIP Trunk
ilyas2011
SIP Trunk
Post by ilyas2011 »
All,
i have trouble in SIP Trunk ...any help...below sip process and attached the log file.
(1)lab> ps -edf|grep sip
mtcl 1854 751 0 13:07 ? 00:00:00 /DHS3bin/servers/sipmotor
mtcl 1855 1854 0 13:07 ? 00:00:11 /DHS3bin/servers/sipmotor
mtcl 2835 1854 0 14:30 ? 00:00:00 /DHS3bin/servers/sipmotor
mtcl 2836 1854 0 14:30 ? 00:00:00 /DHS3bin/servers/sipmotor
mtcl 5397 5283 0 18:11 ttyS0 00:00:00 grep sip
Re: SIP Trunk
Instead of log and process - describe release in your PBX, management, for what you use SIP (SIP trunking, used signaling in SIP TG), another party (OXO, Asterisk...).
ilyas2011
Re: SIP Trunk
Post by ilyas2011 »
system info : R9.0-h1.301-48-mv-c80s1/ SIP Trunk is used instead of ISDN.what do you mean "another party (OXO, Asterisk...)."??
ilyas2011
Re: SIP Trunk
Post by ilyas2011 »
HI, any suggestions on attached traced log....
issues are: cannot to make calls & cannot recive.
ilyas2011
Re: SIP Trunk
Post by ilyas2011 »
hi all, any suggestions on one way calls...attached the log file
umer.saleem
Re: SIP Trunk
Post by umer.saleem »
try creating SIP extension and then check internal communication !
regards.
ilyas2011
Re: SIP Trunk
Post by ilyas2011 »
Hi all, is their any way that SIP trunk can be configure in OXE without the NAT if IP ranges are different from the SIP provider range?
hans-juergen
Re: SIP Trunk
Post by hans-juergen »
No,
NAT has nothing to do with SIP Trunk in OXE. You have to solve the NAT question at you router or firewall. Or you can use a SBC at our side see ALU doc "CPSA27_SBC_for_Enterprise_Voice&Applications_Solutions_ed3"
ilyas2011
Re: SIP Trunk
Post by ilyas2011 »
Hi all, I have problm on SIP trunk call transfer...if any call transfered by on ringing are ok, but if i transfered call after the annoucement the call going to disconnect after 4-5 seconds....anu suggestions on this??
i have attached the log files....
calling from 7782334 to 6800100 and transfered to 6339.
Return to “SIP”
