pchip parity error
mdnazri
pchip parity error
Post by mdnazri »
hi all,
we've encountered below message in the 7450 ESS log, appreciate somebody cld xplain the meaning and how it affect the service or operation of the network element. thanks
336048 2011/03/23 09:30:19.93 MAL MINOR: CHASSIS #2063 Base
"Slot 3 experienced a pchip parity error occurrence on complex 1"
336047 2011/03/23 09:26:19.93 MAL MINOR: CHASSIS #2063 Base
tristaver
Re: pchip parity error
Post by tristaver »
try reload
try remove and put back IOMs
call support
they will ask you do same steps again and send reports
then do RMA
(you can try other Timos too)
similar problem happend when in description was text " - " or similar. router didnt load whole config.
asav
Post by asav »
Hello!
We also fight with this problem for several years. Card restart ('tools perform card power-cycle', or resit) cures the problem. Usually Alcatel agrees to replace it.
This problem can be vary painful, especially when tv mcast traffic flows through this card. But Alcatel cannot resolve this problem for us for five years.
KirkwoodCR
Post by KirkwoodCR »
Usually this means the on-board memory is experiencing an error. It can or cannot be service impacting depending on if the service uses that memory segment that's affected. The Three R process is the recommended method, reset, reseat, RMA. If I may ask, what is the device impacted? IOM? MDA?
thekotaksampah
Post by thekotaksampah »
We found same here. Qchip happening, event there is no port integrated. The integrated not successfully after we clear card the module. This happened in XRS router. Any Hardware issue about it?
Technical Blog: ngoprek.achyarnurandi.id
mivens
Post by mivens »
It's the same procedure as PChip errors.
If it's the first time it's happened on that card and the errors aren't incrementing, monitor.
If the errors are ongoing, power cycle the card but bear in mind if it fails its power on self test, it may not come back so you might want to do this in a maintenance window possibly with a replacement card ready.
If that doesn't fix it, try re-seating then replacing the card.
You have the option of configuring "fail-on-error" if you would like the card to be shutdown automatically if these memory errors occur. This may or may not be appropriate depending on the redundancy in your network.
Return to “7450 ESS”
