Hi All.
Have anyone tried to install 4760 R3.0 on Windows Server 2003? We are now trying that but we find that the installation of 4760 is interrupted. It stops when it tries to insert database in Sybase ASA. Is there any solution for that please?
Thx a lot.
Lam
Installation of 4760 R3.0 on Windows Server 2003
Re: Installation of 4760 R3.0 on Windows Server 2003
Where did you get CDs?Which version exactly?
We have the same problem with CD delivered from Alcatel with version R3.0.15.00c.
Looks like some files from Alcatel's CD can not be read during installation though they exist on CD
I loaded 4760 from BPWS, burned CDs - and installation went fine without any problem
lam
Actually I downloaded the same R3.0.15.00c version.lam wrote:We are using the CD Delivered with version R3.0.15.00c, which is exactly you mentioned. Which version have you downloaded from BPWS that is able to be installed?
Thx.
As I mentioned there is something wrong with the delivered Alcatel' CD itself
lgxbin
Re: Installation 4760 R3.0 problem
Hi Alex
I meet the same problem!
I tried to download the 4760 R3.0.15.00c in the BPWS but I could not find it where it is .So ,could you tell me how can I download 4760 from BPWS.I have the BPWS account and password of course.
Thank you very much for your help!
My best Regards!
Lee
2005-04-15
My best Regards!
Lee
2005-04-15
Hilgxbin wrote:Hi Alex
My best Regards!
Lee
2005-04-15
BPWS/e-support/Technical support/communication server/Software downloading/OmniVista/Omnista 4760/Release 3.0
RuSt
