It makes it possible to establish a link and see if a handset is on or off.
tool dectlocreq d <directory>
It sends mm_info_suggest(locate_req) to the specified handset.
Option n followed by the neqt is also supported.
With dectview com you can check the status.
I made a small and easy script to check all sets in a list.
Installation:
Copy the script to /usr2/mtcl/
Set execution rights: chmod 777 /usr2/mtcl/DectPhone.sh
Start with ./DectPhone.sh
The script creates logfiles DectPhone.* in /tmpd/
DAT_FILE with all sets to check
ON_FILE result - all sets which seems to be on
OFF_FILE result - all sets which seems to be off
LOG_FILE just a log
PID_FILE pid of the script
#!/bin/sh
#set -x
# Read Status of DECT Phones
# (C) Woersty 11:51 09.02.2007
VERSION="2.0"
DAT_FILE="/usr4/tmp/DectPhone.dat"
ON_FILE="/usr4/tmp/DectPhone.on"
OFF_FILE="/usr4/tmp/DectPhone.off"
LOG_FILE="/usr4/tmp/DectPhone.log"
PID_FILE="/usr4/tmp/DectPhone.pid"
decho()
/bin/echo "`date +'[%d/%m/%Y %H:%M:%S]'` ${1}" >>${LOG_FILE}
dnecho()
/bin/echo -n "${1}" >>${LOG_FILE}
/bin/echo -n "${1}"
dnlecho()
/bin/echo "">>${LOG_FILE}
/bin/echo ""
_key()
IFS= read -r -s -n1 -d '' "${@:-_KEY}"
# Hauptprogramm
if [ -f ${PID_FILE} ] ; then
decho "--> Script still running, aborting."
decho "--> Please delete the file ${PID_FILE} if necessary."
exit 0
fi
/bin/echo $$ >${PID_FILE}
decho "*** Starting DectPhone - Version ${VERSION} ***"
decho "*** This script checks, if GAP+ are switched on ***"
MAIN="`/usr2/oneshot/mtcl/role`"
if [ "${MAIN}" = "MAIN" ] ; then
decho "CPU is MAIN, ok."
else
decho "CPU is ${MAIN} -> not MAIN, aborting."
/bin/rm -f ${PID_FILE}
decho "*** Exiting DectPhone ***"
exit 0
fi
cd /usr3/mao
decho "Reading DECT GAP+ sets into $DAT_FILE ..."
/usr2/oneshot/mtcl/tool dectsets |grep "Nbr=" |egrep "AGAP" | /usr/bin/cut -d" " -f4 |/usr/bin/cut -d"=" -f2 >$DAT_FILE
decho "`cat ${DAT_FILE} | wc -l ` DECT sets found"
if [ -f ${OFF_FILE} ] ; then
decho "Saving old DectPhone OFF log file to ${OFF_FILE}.bak "
/bin/mv ${OFF_FILE} ${OFF_FILE}.bak
fi
if [ -f ${ON_FILE} ] ; then
decho "Saving old DectPhone ON log file to ${ON_FILE}.bak "
/bin/mv ${ON_FILE} ${ON_FILE}.bak
fi
/bin/echo -n >> ${ON_FILE}
/bin/echo -n >> ${OFF_FILE}
/bin/cat ${DAT_FILE} | while read nstNbr ; do
dnecho "`date +'[%d/%m/%Y %H:%M:%S]'` Checking DECT ${nstNbr}:"
NULOG=`echo "select nulog,numan from poste where numan='${nstNbr}';" | /usr2/fab/cuser . m | /bin/grep -v "select" | /bin/grep ${nstNbr} | /usr/bin/cut -d" " -f2`
if [ -z "${NULOG}" ] ; then
decho "--> ${nstNbr}: No user."
else
dnecho " check communication "
STAT="`/usr2/oneshot/mtcl/tool dectview com |/bin/grep ${nstNbr} |/usr/bin/cut -d"/" -f3 |/usr/bin/cut -d" " -f1`"
dnecho ${STAT}
if [ "${STAT}" = "STABLE" ] ; then
OUTSERV="false"
dnecho " -> Link established ->ON"
PORT="`echo ${COMMI} |egrep 'PAGIN|STAB|PART_REL' |/usr/bin/cut -d":" -f4 |/usr/bin/cut -d"/" -f2 |/usr/bin/cut -d" " -f1`"
CPL="`echo ${COMMI} |egrep 'PAGIN|STAB|PART_REL' |/usr/bin/cut -d":" -f5 |/usr/bin/cut -d"/" -f2`"
CRY="`echo ${COMMI} |egrep 'PAGIN|STAB|PART_REL' |/usr/bin/cut -d":" -f5 |/usr/bin/cut -d"/" -f1`"
POSITION=$CRY"-"$CPL"-"$PORT
dnlecho
else
OUTSERV="true"
dnecho "-> No conversation -> resetting phone "
/usr2/oneshot/mtcl/tool dectlocreq d ${nstNbr} >/dev/null 2>/dev/null
fi
TIMEDIFF=0
TIMESTART=`date +%s`
while [ "${OUTSERV}" = "true" -a ${TIMEDIFF} -lt 7 ]
do
COMMI="`/usr2/oneshot/mtcl/tool dectview com |/bin/grep ${nstNbr} `"
STAT="`echo ${COMMI} |egrep 'PAGIN|STAB|PART_REL' |/usr/bin/cut -d"/" -f3 |/usr/bin/cut -d" " -f1`"
if [ "${STAT}" = "PAGING" ] ; then
STAT=":"
fi
dnecho ".${STAT}"
if [ "${STAT}" = "STABLE" -o "${STAT}" = "PART_REL" ] ; then
dnecho "->ON"
dnlecho
OUTSERV="false"
fi
/bin/usleep 250000
TIME=`date +%s`
TIMEDIFF=`expr ${TIME} - ${TIMESTART}`
done
if [ "${OUTSERV}" = "false" ] ; then
echo "${nstNbr}-${POSITION}-${STAT}" >> ${ON_FILE}
else
echo ${nstNbr} >> ${OFF_FILE}
dnecho "NO REPLY->OFF"
dnlecho
fi
fi
done
decho "Active sets: "
/bin/cat ${ON_FILE}
/bin/cat ${ON_FILE} >>${LOG_FILE}
decho "Sets without paging reply:"
/bin/cat ${OFF_FILE}
/bin/cat ${OFF_FILE} >>${LOG_FILE}
decho "*** Exiting of DectPhone normally ***"
exit 0
