Hi guys,
After sending to OXE INVITE msg, it answers 407 response. Is it possible to force it to answer 401 instead?
SIP Authentication
Re: SIP Authentication
Why you want instead of "407 Proxy Authentication Required" to send "401 Unauthorized"?
May be in IP/SIP/Proxy - Only authenticated incoming calls=yes?
sipop
did you managed your ip in a sip external gateway? Then 407 is correct. 401 is only for sip users
hamster
Hello
The option "Only Authenticated incomming calls" force all "Request: INVITE" messages to be authenticated individually.
This is separate from authentication dialog during "Request: REGISTER" and enhances security.
I've had issues with this option on some UA's.
I haven't dug deep into checking weather the OXE or the UA don't follow RFC...
...so I turn it of...
OmniPCX Enterprise R10, j1.410.38.c
┌─Review/Modify: SIP Proxy─────────────────────────────────────────────────────┐
│ Instance (reserved) : 1 │
│ SIP initial time-out : 500 │
│ SIP timer T2 : 4000 │
│ Dns Timer overflow : 5000 │
│ Timer TLS : 30 │
│ Recursive search + False │
│ Minimal authentication method + SIP Digest │
│ Authentication realm : anything │
│ Only authenticated incoming calls + False │
│ Framework Period : 3 │
│ Framework Nb Message By Period : 25 │
│ Framework Quarantine Period : 1800 │
│ TCP when long messages + False │
│ Retransmission number for INVITE : 3 │
└──────────────────────────────────────────────────────────────────────────────┘I haven't dug deep into checking weather the OXE or the UA don't follow RFC...
