OmniVista 4760 Adminnmc password
danielp127
Post by danielp127 »
Hello
We have just taken over a site and dont have the password for the adminnmc account. Is there any way we can reset it or access it. The account we have access to doesnt have Traffic Analysis and we need to run a report on the attendant consoles.
gvozikis
Re: OmniVista 4760 Adminnmc password
Post by gvozikis »
If you know directory manager password you can reset the password of adminnmc using the toolsOmnivista.exe which is located under 4760\bin.
cvjo
Post by cvjo »
1) Open dirmanag.exe avaiable in the location <4760 Install path>\bin with login as cn=diretory manager and password as <installation password>
2) Go to the following dn and change the password and save it
uid=AdminNmc,ou=Administrators,ou=Administration,o=alcatel,o=directoryRoot
ACSE OXE
ACSE Omnivista 4760
Developer 8770
Return to “4760”
