OXO Group Voice Mail
edddies
Post by edddies »
I have a situation at a customer site where there are 4 phones in one department. These phones all have supervisor keys on them so that they know when the other phones are ringing. My problem is that I need all of these phone to goto one central voicemail for that department. I have spent a couple days trying to figure out a solution but to this point I am having no luck. I am using OMC 800 23.1b. Thanks!!
Re: OXO Group Voice Mail
Make a virtual extension with VM and imm fwd it to the VoiceMail. Use it as your voice mail number for your sets. You can configure a voice mail key on each terminal with virtual terminal mcdu to consult the voice mailbox.
