First of all I would like to congratulate the owner of this forum. This is the first time that I post and this forum is really helpful.
I have a problem on connecting to 4635 voice mail via serial port( the cable is the 3BA58107AA serial ). When I attach a modem on this cable and call it, the modem replies but nothing happens. I beleive I need specific modem setup. Can anyone assist or propose another type of connection such LAN ?
Thank you
Access to 4635
4635 via BRMA
To connect to the 4635 via BRMA you must: First connect the cable to the 4400 back plane slot right at the very top! Then connect the black marked 29 pin connector to the ExC port on the BRMA - the port should be configured by default. Connect your pc (serial port) to the ExA port. You will get a prompt:
Rma Login: (type) rma
Password: (type) rma
rma:(type)cnx 5
rma:(type)cnx 5
gundam
no you don't, the 4635 will communicate with teh CPU via the c1 link. One can backup the VM database via swinst. You will need an external IP cabele if you want to FTP it to direct to a PC (note do now use microsoft FTP to perform the vm backup, it will not work, thisis a kown problem within Alcatel).
