Port 1/13 = Firewall and DHCP for VLAN 7 and 8 and the default (1)
Port 1/23 = Accesspoint with 2 SSIDS depending on the SSID = VLAN 7 or 8
Port 1/24 = Accesspoint with 2 SSIDS depending on the SSID = VLAN 7 or 8
So naturaly i set all involved ports to mobile ports and created an ip based rule for each vlan.
When WLAN clients sign on, port 1/23 and 1/24 start switching between vlans 7 and 8 (according to the webmanagement)
But port 1/13 remains on VLAN 1 and clients therefore have no connection to the router.
Here my terminal output:
-> write terminal
! Stack Manager :
! Chassis :
system name vxTarget
system timezone CET
! Configuration:
! VLAN :
vlan 1 enable name "VLAN 1"
vlan 1 mobile-tag enable
vlan 7 1x1 stp disable flat stp disable name "VLAN 7"
vlan 7 mobile-tag enable
vlan 8 1x1 stp disable flat stp disable name "VLAN 8"
vlan 8 mobile-tag enable
vlan 8 port default 1/22
vlan port mobile 1/13 bpdu ignore enable
vlan port mobile 1/23 bpdu ignore enable
vlan port mobile 1/24 bpdu ignore enable
vlan 1 ip 10.10.10.0 255.255.255.0
vlan 7 ip 10.10.50.0 255.255.255.0
vlan 8 ip 10.10.60.0 255.255.255.0
! VLAN SL:
! IP :
ip service all
ip interface "VLAN_1" ifindex 2
ip interface "vlan_1" address 10.10.10.80 mask 255.255.255.0 vlan 1 ifindex 3
! IPX :
! IPMS :
ip multicast status enable
ip multicast querying enable
ip multicast spoofing enable
ip multicast zapping enable
ip multicast proxying enable
ip multicast querier-forwarding enable
ip multicast flood-unknown enable
ip multicast helper-address 10.10.10.13
ip multicast vlan 2 status disable
ip multicast vlan 2 querying disable
ip multicast vlan 2 spoofing disable
ip multicast vlan 2 zapping disable
ip multicast vlan 2 version 2
ip multicast vlan 2 robustness 2
ip multicast vlan 2 query-interval 125
ip multicast vlan 2 query-response-interval 100
ip multicast vlan 2 last-member-query-interval 10
ip multicast vlan 2 router-timeout 90
ip multicast vlan 2 source-timeout 30
ip multicast vlan 2 proxying disable
ip multicast vlan 2 unsolicited-report-interval 10
ip multicast vlan 2 querier-forwarding disable
! AAA :
aaa authentication http "local"
! PARTM :
! AVLAN :
avlan 1 auth-ip 10.10.11.175
! 802.1x :
! QOS :
! Policy manager :
! Session manager :
! SNMP :
! RIP :
! OSPF :
! BFD-STD :
! ISIS :
! IPv6 :
! IPSec :
! IP multicast :
ip static-route 0.0.0.0/0 gateway 10.10.10.1 metric 65534
! RIPng :
! OSPF3 :
! BGP :
! Health monitor :
! Interface :
! Udld :
! Link Aggregate :
! Port Mapping :
! VLAN AGG:
! 802.1Q :
! Spanning tree :
bridge mode 1x1
! Bridging :
! Bridging :
! Port mirroring :
! UDP Relay :
ip helper per-vlan only
ip helper forward delay 0
ip helper maximum hops 5
ip helper pxe-support enable
ip helper agent-information policy replace
! Server load balance :
! System service :
swlog console level info
debug fscollect enable
! SSH :
! Web :
! AMAP :
! LLDP :
! Lan Power :
! NTP :
! RDP :
! VLAN STACKING:
! Ethernet-OAM :
! EFM-OAM :
! ERP :
! SAA :
! DHCP Server :
thx
dadadum
