IP touch 4068 reboots when LLDP is active
wizkash
Post by wizkash »
I have an issue: Ip touch 4068 reboots when LLDP is active on cisco switch 3560. When LLDP is disabled, there is no issue. However, 4028 works fine even with LLDP active.
Has anyone come across this issue before??
OXE R9.1 patch 22
Thanks.
krzysioD
Re: IP touch 4068 reboots when LLDP is active
Post by krzysioD »
known problem.
Wait till some new patch, in 26 is still has a problem.
wizkash
Post by wizkash »
Thanks krzysioD. :)
magnum
Post by magnum »
I am fairly sure this is sorted on 25a
oldboy
Post by oldboy »
Yes it is sorted in 25a
krzysioD
Post by krzysioD »
25a with security?
