SILENT - Dynamic key on incoming call
swinstu
Post by swinstu »
I have a client who wants to stop all 8 and 9 series handsets that receive incoming calls by pressing dynamic key on left screen for SILENT. So they want to deactivate the "SILENT" feature that appears beside "Take Call"
Is it possible to program in software. Unable to find in categories, specific telephone facilities, system or even users.
I am guessing its built into the firmware of the handset but just need to double check.
SWINTU
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Konstantinos.E
Re: SILENT - Dynamic key on incoming call
Post by Konstantinos.E »
hi
what about "do not disturb"?
Alca_holic
swinstu
Post by swinstu »
No do not disturb will be worse. Trying to make people answer their phones as they are hitting silent to avoid calls. These ext don't have voicemail and not in a call center.
Please advise if it is possible to deactivate the Silent option on incoming calls on 8&9 series handsets? So users cannot silent their extensions. (hope that is clear enough for a question)
SWINSTU
ACSE OXE R12.1
Konstantinos.E
a ok now is clear.i think this is not possible.
Alca_holic
swinstu
Post by swinstu »
I also think the same as believe its part of the phone firmware. Told customer to deploy call center instead to monitor agents who abandon calls etc.
thanks for your feedback. But if anyone has a different opinion or suggestion then please do provide input.
SWINSTU
ACSE OXE R12.1
Return to “Specific Telephone Services”
