Hello
I read somewhere that os10k support 802.1aq spb, but in the os10k configuration guide is nothing about that. So the question is the MC-LAG is the same as SPB ? if not how can i configure SPB ?
shorthes path bridging 802.1aq or MC-LAG
cedric1
Re: shorthes path bridging 802.1aq or MC-LAG
hello,
MC-LAG is LACP actif-actif to 2 10K HW.
SPB is not released in 10K sw nowans is different from MC-LAG.
Cedric
Cedric
m00n
do you know when spb will be release in 10k ? it will be offered also on 6850E ? i am really interested in spb
alumed
SPB is OS10K/OS6900 only.
Have a look at reference no. 5 of the SPB page on wikipedia.
cedric1
hello
Datacenter bridging is planned for Q1 2012. This will be a good step for this line of product.
Cedric
Cedric
Acse
hello
As I was checking, MC-LACP and 802.1.aq are based on the same RFP
http://tools.ietf.org/agenda/81/slides/l2vpn-3.pptx
also check
http://www.scribd.com/doc/67558757/Data ... hitectures
I had hands on it in our lab, SPB and MC-LACP are the same.
hope that helps
also check
hope that helps
