Eva_tool
airwolf
Eva_tool
Post by airwolf »
Hi All
I am having a problem accessing Eva_tool. I get a back trace when i try, has anyone seen this before
Grammar error or Eva_tool.dct corrupted
LIBC caught SIGSEGV in 6452
Registers:
EFLAGS = 0x00010246
EAX = 00000000
EDX = 0x00000028
EIP = 0x080721d7
EDI = 0x080721d7
ESI = 0x08083323
EBP = 0xbffffbe0
EBX = 0x6f206572
ECX = 0x0807ffe6
Backtrace :
Backtrace recurence: 0 pc:0x080721d7 ebp:0xbffffbe0
Backtrace recurence: 1 pc:0x08072783 ebp:0xbffffbf0
Backtrace recurence: 2 pc:0x08072716 ebp:0xbffffc04
Backtrace recurence: 3 pc:0x08067c7f ebp:0xbffffc20
Backtrace recurence: 4 pc:0x08067cb0 ebp:0xbffffc3c
Backtrace recurence: 5 pc:0x4002d5a0 ebp:0xbffffc78
Backtrace recurence: 6 pc:0x08063a36 ebp:0x00000000
Segmentation fault
murraya
Re: Eva_tool
Post by murraya »
hi, try a search for eva tool as this has been discussed before. Seems to be okay after a reboot though.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
airwolf
Re: Eva_tool
Post by airwolf »
Will try a search , did a reboot last night though but still causing problem
tincho.rn
Re: Eva_tool
Post by tincho.rn »
Sorry, but perhpas you get ungry because of my basic advise. But did you create the voice mail? Do you have 4645 in service? $>config 18 Regards
Eliott
Re: Eva_tool
Post by Eliott »
http://alcatelunleashed.com/viewtopic.p ... 781#p63237
As workaround you can copy the file /usr2/oneshot/mtcl/Eva_tool.dct to /usr2/oneshot/mtcl/Eva_tool.dct.bak
Then you can start and use the Eva_tool - of course without dictionary file - but you can use and guess the options from the displayed variable names. (e.g. reset password option)
With R9.1 i1.605.28 comes a new Eva_tool binary
A solution? - I don't know.
airwolf
Re: Eva_tool
Post by airwolf »
Thanks for the reply, after 2 reboot it seems ok for now
Return to “Voicemail (46x5)”
