425 Can't build data connection
426 Data connection errorPS: I ask this because scp doesn't work in both directions. It seems for me that early AOS Switches crash for transferring files from remote server and actually AOS Switches doesn't accept incoming scp transfers:
scp K2os.img admin@[Omniswitch-IP]:/flash/working/
admin’s password for keyboard-interactive method:
Received disconnect from [Omniswitch-IP]: 2: ssh + command not available
lost connection
results in:
MON MAR 07 19:01:05 2011 SSH info Session 8 New SSH Connection from [remote-server] port 52820
MON MAR 07 19:01:13 2011 SYSTEM info memPartRealloc: invalid block 0x651d800 in partition 0x4b6b14.
MON MAR 07 19:01:13 2011 SSH error [SSH 8] xrealloc: out of memory (new_size 32768 bytes)
MON MAR 07 19:01:14 2011 CSM-CHASSIS info == CSM == CS excep handler: exception 768 in task 0x652d570
MON MAR 07 19:01:14 2011 CSM-CHASSIS info == CSM == Excep in task: sshd_ct2 PC : 0x31fe34
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 1) 32357c vxTaskEntry +5c : sshd_ct ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 2) 154a9b8 sshd_ct +1c4: do_authentication2 ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 3) 154d9bc do_authentication2+8c : do_authenticated ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 4) 1567120 do_authenticated2+48 : server_loop2 ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 5) 15645d0 server_loop2 +dc : process_buffered_input_packets (
MON MAR 07 19:01:15 2011 CSM-CHASSIS info == CSM == )
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 6) 156447c process_buffered_input_packets+24 : dispatch_run ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 7) 1557b18 dispatch_run +108: server_input_channel_req ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 8) 1564bc4 server_input_channel_req+cc : packet_put_int ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 9) 1560c04 packet_put_int +20 : buffer_put_int ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 10) 154ffe4 buffer_put_int +2c : buffer_append ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS info === CS === 11) 357464 memcpy +20 : bcopy ()
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm **************** STR ****************
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Level : ERROR DETECTED - APPLICATION FATAL
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Not an application managed by Chassis Supervision
taskId : 0X
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Source file name : ??????
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Line number in the file : 0
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Error number : 0X00000300
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Comments : exception in task 0x652d570
MON MAR 07 19:01:15 2011 CSM-CHASSIS alarm Data Size : 00000040
taskId : 0X
MON MAR 07 19:01:15 2011 CSM-CHASSIS info == CSM == !!! REBOOT STACK !!!
MON MAR 07 19:01:44 2011 SYSTEM info Switch Logging device ‚/flash/swlog2.log‘ enabled for output
MON MAR 07 19:01:44 2011 SYSTEM info Switch Logging device ‚/flash/swlog1.log‘ enabled for output
MON MAR 07 19:01:58 2011 SYSTEM info Switch Logging device ‚/dev/console‘ enabled for output
MON MAR 07 19:01:58 2011 CSM-CHASSIS info == CSM == === Chassis Supervision Starting Up ===Code: Select all
scp [some.file] admin@[remote-server]:/flash/
admin's password for keyboard-interactive method:
exec request failed on channel 0
lost connection
