Hi All
Is it possible to reset an analogue port on an sli 16 (Z) card without resetting the entire card using rstcpl? i have one port that i want to reset without downing all the ports.
many thanks in advance
How can you reset an analogue port?
Re: How can you reset an analogue port?
hi, you can try termstat d 1234 (extn number) or if you know the neqt use outserve xyz (neqt) then inserve xyz.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
objohnuk
Thanks for the reply but termstat d xxxx doesn't work on analogue ports. Works fine on ip and digital though. I'll try outserve and inserve, but how can I find the neqt if termstat doesn't work on analogue? Catch 22!!
outserv d EDN
inserv d EDN
Regards.
outserv d EDN
inserv d EDN
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
try "tradna extension_number" to find the neqt.
