OmniSwitch 7000 Trunking
wiltim
Post by wiltim »
I'm sure you guys get this all the time...
I'm a Cisco guy and am having trouble resolving in my brain how to configure trunk ports between two OS 7000s and ultimately, add a Cisco 2960 to the mix.
I think I understand what the commands are but want to run it by the 'board' for a blessing...
I have two OmniSwitches connected for redundancy from 1/1 to 1/1 amd 2/1 to 2/1
I have several VLANs 1 (default), 3,4,5,6,7,20
Right now all the traffic passes properly between switches. What I need to do now is to add a new VLAN, 25, and allow it to pass across the trunk. The commands I THINK I need to enter are:
On SW1
vlan 25 enable name "u-25" (create VLAN 25)
vlan 25 port default 7/1 (Assign Access Port)
vlan 25 802.1q 1/1 "u-25" (Allow trunk port to pass VLAN 25 tagged)
vlan 25 802.1q 2/1 "u-25" (Allow trunk port to pass VLAN 25 tagged)
bridge 25 protocol 1w (Configures Bridge protocol for that VLAN)
bridge 25 priority 1 (Configures Bridge protocol priority for that VLAN)
On SW2
bridge 25 priority 2 (Configures Bridge protocol priority for that VLAN)
Now here is where I get fuzzy....how do I make a port a trunk port for connection to a Cisco...do I just assign 802.1q config to it? So if I wanted port 3/1 to be a trunk I would enter this:
vlan 3 802.1q 3/1 "u-3"
vlan 4 802.1q 3/1 "u-4"
vlan 5 802.1q 3/1 "u-5"
vlan 6 802.1q 3/1 "u-6"
vlan 7 802.1q 3/1 "u-7"
vlan 20 802.1q 3/1 "u-20"
vlan 25 802.1q 3/1 "u-25"
Below is what I think is the important aspects of teh configs, please let me know if you want to review more:
SW1
! Configuration:
! VLAN :
vlan 1 enable name "Default"
vlan 3 enable name "u-3"
vlan 3 router ip 205.105.132.2 255.255.255.192 e2
vlan 3 port default 1/2
vlan 3 port default 1/3
vlan 3 port default 1/4
vlan 3 port default 1/6
vlan 3 port default 1/7
vlan 3 port default 1/8
vlan 3 port default 2/2
vlan 3 port default 2/5
vlan 3 port default 2/6
vlan 3 port default 6/1
vlan 3 port default 7/22
vlan 3 port default 7/23
vlan 4 enable name "u-4"
vlan 4 router ip 5.5.2.66 255.255.255.192 e2
vlan 4 port default 2/3
vlan 5 enable name "u-5"
vlan 5 router ip 5.5.2.158 255.255.255.224 e2
vlan 5 port default 7/24
vlan 6 enable name "u-6"
vlan 7 enable name "u-7"
vlan 7 router ip 5.5.1.2 255.255.254.0 e2
vlan 7 port default 6/10
vlan 7 port default 7/7
vlan 20 enable name "u-20"
vlan 20 router ip 5.5.3.2 255.255.255.0 e2
vlan 20 port default 6/2
vlan 20 port default 7/21
! 802.1Q :
vlan 3 802.1q 1/1 "u-3"
vlan 4 802.1q 1/1 "u-4"
vlan 5 802.1q 1/1 "u-5"
vlan 6 802.1q 1/1 "u-6"
vlan 7 802.1q 1/1 "u-7"
vlan 20 802.1q 1/1 "u-20"
vlan 3 802.1q 2/1 "u-3"
vlan 4 802.1q 2/1 "u-4"
vlan 5 802.1q 2/1 "u-5"
vlan 6 802.1q 2/1 "u-6"
vlan 7 802.1q 2/1 "u-7"
vlan 20 802.1q 2/1 "u-20"
! Spanning tree :
bridge 1 protocol 1w
bridge 1 priority 1
bridge 3 protocol 1w
bridge 3 priority 1
bridge 4 protocol 1w
bridge 4 priority 2
bridge 5 protocol 1w
bridge 5 priority 1
bridge 6 protocol 1w
bridge 6 priority 2
bridge 7 protocol 1w
bridge 7 priority 1
bridge 20 protocol 1w
bridge 20 priority 2
bridge 4 1/1 path cost 5
bridge 6 1/1 path cost 5
bridge 20 1/1 path cost 5
bridge 3 1/2 connection edgeport
bridge 3 1/3 connection edgeport
bridge 3 1/4 connection edgeport
bridge 3 1/6 connection edgeport
bridge 3 1/7 connection edgeport
bridge 3 1/8 connection edgeport
bridge 1 2/1 priority 10
bridge 3 2/1 priority 10
bridge 5 2/1 priority 10
bridge 7 2/1 priority 10
bridge 3 2/2 connection edgeport
bridge 4 2/3 connection edgeport
bridge 3 2/5 connection edgeport
bridge 3 2/6 connection edgeport
bridge 20 3/1 connection edgeport
bridge 20 3/2 connection edgeport
bridge 20 3/3 connection edgeport
bridge 20 3/4 connection edgeport
bridge 20 3/5 connection edgeport
bridge 20 3/6 connection edgeport
bridge 20 3/7 connection edgeport
bridge 20 3/8 connection edgeport
bridge 20 3/9 connection edgeport
bridge 20 3/10 connection edgeport
bridge 20 3/11 connection edgeport
bridge 20 3/12 connection edgeport
bridge 3 6/1 connection edgeport
bridge 20 6/2 connection edgeport
bridge 20 6/3 connection edgeport
bridge 20 6/4 connection edgeport
bridge 20 6/5 connection edgeport
bridge 20 6/6 connection edgeport
bridge 20 6/7 connection edgeport
bridge 20 6/8 connection edgeport
bridge 3 7/22 connection edgeport
bridge 3 7/23 connection edgeport
bridge 5 7/24 connection edgeport
SW2
! Configuration:
! VLAN :
vlan 3 router ip 5.5.2.4 255.255.255.192 e2
vlan 4 router ip 5.5.2.8 255.255.255.192 e2
vlan 6 router ip 5.5.2.11 255.255.255.224 e2
vlan 6 port default 6/2
vlan 7 router ip 5.5.1.4 255.255.254.0 e2
vlan 20 router ip 5.5.3.4 255.255.255.0 e2
vlan 20 port default 6/3
vlan 20 port default 6/4
vlan 20 port default 6/5
vlan 20 port default 6/6
vlan 20 port default 6/7
vlan 20 port default 6/8
vlan 20 port default 8/14
vlan 20 port default 8/19
vlan 20 port default 8/20
! 802.1Q :
! Spanning tree :
bridge 1 priority 2
bridge 3 priority 2
bridge 4 priority 1
bridge 5 priority 2
bridge 6 priority 1
bridge 7 priority 2
bridge 20 priority 1
bridge 6 6/2 connection edgeport
bridge 20 8/20 connection edgeport
cedric1
Re: OmniSwitch 7000 Trunking
Post by cedric1 »
hi
what you want to do is ok for trunking, it must work
cedric
