R800_041_002 + LoLa400_6_1 = NOTHING HAPPENS???
MTConsulting
I have a new blank Power CPU, I am trying to load the latest R8 version onto it with the latest LoLa and I get the Boot Desktop showing "found in cache... the correct IP address for Local & Client" there is only 1 line of this (normally there are several?)
then I get the TFTP Desktop showing 4 lines, 3 lines of OCTEL,Send & 1 Line ofASCI, Send.
Then on the LoLa APP window it just sitting 'waiting for board download request'????
Yes, the RED jumper has been moved,
YES the folder is shared to allow LoLa access to the files,
I have worked on OXO since 1.1 and it never stops amazing me what a pain in the ass LoLa continues to be when trying to format/reload a CPU??
Any ideas guys greatly appreciated
PC is running Windows 7, previous version worked fine.
Cheers,
MTC
Cheers,
MTC
- Konstantinos.E
MTConsulting
Re: R800_041_002 + LoLa400_6_1 = NOTHING HAPPENS???
yes mate...got it...completely forgot it..AGAIN!..cheers!!
Asad Ullah QUraishi
Hello Mates,
I got the same query regarding the Release download, and guess what, i even turned the Firewall & the antivirus Off but still it's stuck on Waiting for board download request,
I don't understand what is the issue..
I even switched to the older version of my OS. Windows XP but still it is the same.
I really need some help on that.. thanks for your co-operation, Mates
Asad Ullah QUraishi
Hi mates,
I got the same issue, i even turned off the firewall as well as the antivirus, but still it is stuck on Waiting for download request. and some times it shows a "SAMBA Error" . Any idea what is it all about ?
Really need some help on it
- tot3nkopf
Probably the release folder is not shared properly. You can share it manually.Asad Ullah QUraishi wrote:
Read all lola related posts on this forum before asking a question that has been already answered.
don´t forget to set the PCs IP-Address in the registry of your PC. Also please use the latest version of Lola (400_12.1).
Best regards
OXO-Man
Best regards
OXO-Man
ACSE OXO R8.0
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
.. and a lot of more...!
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
astuto00
hello friends I solve this problem compratiendo have located the folder where the OXO release and assign full control to all users.
best regards.
best regards.
He shared the OXO releases folder with full permissions. Google translated a little bad there
astuto00
so the folder is shared with full permissions to all users, sorry that my English is not very good
