In Brazil, calls may be paid by called user.
In R2, OXE is ready to Denied or allow collect calls by COS or TrunkGroup.
ISDN still not implemented. Above we can find collect call trace.
| (808938:000025) Concatenated-Physical-Event :
| long: 53 desti: 0 source: 0 cryst: 2 cpl: 6 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 12 c5
|SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 9c -> T2 : B channel 28 preferred
| IE:[4a] UNKNOWN (l=1) 81
| IE:[6c] CALLING_NUMBER (l=12) -> 21 83 Num : 9191374488
| IE:[70] CALLED_NUMBER (l=5) -> c1 Num : 3046
| (808938:000026) 1344: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : STATUS [7d] Call ref : 92 c5
| IE:[08] CAUSE (l=3) 81 e3 4a -> [e3]
| INFORMATION ELEMENT NON-EXISTENT OR NOT IMPLEMENTED
| IE:[14] CALL_STATE (l=1) 06
| (808938:000027) 1344: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 92 c5
| IE:[18] CHANNEL (l=3) a9 83 9c -> T2 : B channel 28 exclusive
| (808938:000028) 1344: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 92 c5
| IE:[1e] PROGRESS_ID (l=2) 81 88
| (808959:000029) 1344: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 30 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT (07) Call ref : 92 c5
| IE:[4c] CONNECTED_NUMBER (l=10) -> 01 81 Num : 33483046
Collect calls over ISDN
oliveira_Arthur
Arthur Oliveira
Arthur Oliveira
Re: Collect calls over ISDN
This IE - 4a is used for packet communication (X.25).
For reverse charging feature you provider should send FACILITY IE
oliveira_Arthur
How we can see on Aculab Docs, http://www.pulsewan.com/data101/q931.pdf, 4A = 1001010 is the IE value to Reverse Charging.
The PNC is sending correct code facility. Where on OXE I can change this to Reverse Charge?
Thanks.
Thanks.
Arthur Oliveira
Arthur Oliveira
Your PNC has a certificate from Aculab that it complies with Q.956? OK. That means they have kind of special standards comparing to the rest of the world.oliveira_Arthur wrote:How we can see on Aculab Docs, http://www.pulsewan.com/data101/q931.pdf, 4A = 1001010 is the IE value to Reverse Charging.
Thanks.
Read the Q.931. It is written there - IE 4a is for packet X.25 packet communication, not for the channel communication.
If you want "reverse charging" feature (ITU style), ALU (as any telecom manufacturer) would be kind enough to ask your provider to comply with Q.956.
