Hi guys,
I would like to ask about E&M-4TL board of Crystal Hardware. It seems supported only E&M type1 and type2 regarding the system document. Is it possible to connect E&M type5 as well?
I have a new project and have to connect OXE to another PABXs (probably NEC SV8500 and Panasonic Digaport. Both are Japanese PABX). Please advise.
Best Regards,
Hi! - I moved the server over the week end to handle the daily incoming connections (about 200K/day) but it looks like I aimed too low for the resources. I'm going to have to move this server (hopefully for the last time) this week. I'm sorry for the interruption.
E&M Type5
Re: E&M Type5
Oh God, did not touch that stuff for a decade at least.
Yes, EMTL supports only Type I and II.
But you can easily connect Type II with Type V trunks with proper wiring. PM me.
wolfgar
Re: E&M Type5
Hi Alex,
Thank you for your reply.
As Japanese PABX, it's standard still...
Thank you for your advising.
BTW, do you have any good doc of the connection between EMTL and Type V trunk?
Re: E&M Type5
I have a sketch on a paper of connection between switches.wolfgar wrote: do you have any good doc of the connection between EMTL and Type V trunk?
Check any docs on E&M available - e.g, Cisco has a few very good documents on that. See Understanding and Troubleshooting Analog E&M Interface Types and Wiring Arrangements
Also It depends which equipment you're trying to connect - two PABX' together (in this case connection is crossed E->M, M->E) or PABX and MUX (in that case connection is E->E, M->M).
wolfgar
Re: E&M Type5
Hi Alex,
Thank you so much for your advising.
I will confirm it with an engineer of another bender PABX.
chs
Re: E&M Type5
Could you share your sketch how to connect Type 2 on EMTL and Type 5 on other vendor PBX ?alex wrote: I have a sketch on a paper of connection between switches.
chs
Re: E&M Type5
Could you share your sketch how to connect Type 2 to Type 5 ?alex wrote: I have a sketch on a paper of connection between switches.
Any kind of the related information will be highly appreciated.
Thanks for your support in advance.
Re: E&M Type5
Cisco used to have a very good page on E&M signalling but seems they (re)moved it. This one is pretty good E & M Signaling.chs wrote: Any kind of the related information will be highly appreciated.
And here goes my sketch.
chs
Re: E&M Type5
Hi alex,
Could you send your image to my email ( chs0805@gmail.com ) ?
Again, thank you very much in advance.
Thanks for your support, but I cannot see your image and even cannot download it from URL.alex wrote:And here goes my sketch.
chs
Re: E&M Type5
Hi Alex,
Thanks for your information, but unfortunately, my partner fails to interworking between Type 2 on ELTM and Type 5 on other PBX.
Since I and my partner are not familiar with E&M and especially ELTM, could you check what is the correct configuration for Type 2 on ELTM ?
My partner tried the last 2 configurations, Open switching – 4 Wire and Closed switching – 4 Wire (Ma and Mb Transmission Xi03, Xi04, Xi05, Xi06). Is it correct for Type 2 ? And is there any other required configuration for Type 2 ?
Any advice will be highly appreciated and thanks in advance for your help.
