Hi all!
I want config interface loopback. Can you please provide sample config commands
interface loopback
andykai
Re: interface loopback
Hi you can add another loopback interface by adding loopback in the interface configuration
e.g:
configure
router
interface "loop1"
address 10.10.10.1/32
loopback
exit
exit
e.g:
configure
router
interface "loop1"
loopback
exit
exit
khaledsaadeh1
i have configure the loopback interface on SR7750 and insert that interface under MPLS but the MPLS stay down ,like below
A:SR1-TAR# show router mpls interface
MPLS Interfaces
Interface Port-id Adm Opr TE-metric
system system Up Up None
Admin Groups None
Srlg Groups None
CR1 1/1/1 Up Up None
Admin Groups None
Srlg Groups None
CR2 2/1/1 Up Up None
Admin Groups None
Srlg Groups None
Loopback 0 loopback Up Down None
Admin Groups None
Srlg Groups None
Interfaces : 4
MPLS Interfaces
Admin Groups None
Srlg Groups None
Admin Groups None
Srlg Groups None
Admin Groups None
Srlg Groups None
Admin Groups None
Srlg Groups None
Interfaces : 4
thecandymancan
What release are you using? I just created one and mine says Oper N/A (same goes for RSVP interfaces).
Are you trying to terminate an LSP on the loopback address as opposed to the system address? If you're doing LDP over RSVP remember the 7750 will only advertise LDP labels for the system address only by default.
MPLS Interfaces
loop1 loopback Up N/A None
Admin Groups None
Srlg Groups None
show router rsvp interface
RSVP Interfaces
Interface Total Active Total BW Resv BW Adm Opr
Sessions Sessions (Mbps) (Mbps)
loop1 0 0 100 0 Up N/A
MPLS Interfaces
Admin Groups None
Srlg Groups None
RSVP Interfaces
erwin
Hi All,
I found this message when i am trying to add port on a loopback interface:
A:LAB# configure router interface "lo0"
*A:LAB>config>router>if# port 1/2/10
INFO: PIP #1323 Cannot modify the port binding, remove the port binding first
could we add port on a loopback interface?
zeips
not sure if its possible but also not sure why would u ever want to add port to the loopback interface?
anyway, issue this: show router interface | m 1/2/10
and verify if this port is already added to other interface, if yes then removed it and try again
erwin
i'm only curious what is the differences between system and loopback interface on ALU.zeips wrote:not sure if its possible but also not sure why would u ever want to add port to the loopback interface?
The system interface is used by all routing protocols as default source, or destination for MPLS tunnels.erwin wrote:i'm only curious what is the differences between system and loopback interface on ALU.zeips wrote:not sure if its possible but also not sure why would u ever want to add port to the loopback interface?
Until the latest SR releases, a MPLS tunnel's far end must be the system address.
But the difference of a "interface loopback0" with the loopback argument added, and "interface system" is close to none.
The system interface is a fullblown loopback, but an interface a lot of the OS are depended upon.
[flash=]
Christoffer
Network System Expert Norway
Nokia SRA #265
Cisco CCNP Certified
LinkedIN
[/flash]
Christoffer
Nokia SRA #265
[/flash]
