Associated sets and voicemail .... part II
JHades
Post by JHades »
Same question as a while ago, but they keep pushing it :roll:
I have 2 users: A and B. Both are associated sets of each other. But they are still not satisfied. Both want a voicemail on their number, but with following flow:
call on A >> doesn't answer >> call to assoiated set B >> doesn't answer >> call to voicemail
and .... the other way around: call on B >> .....
I can't get the calls to end on the voicemail system. I've tried forward on no reply to voicemail, but then the call doesn't get to the associated set.
I have adjusted following features:
* Phone Facilities: Voice Mail Forwarding = Ring Final Set Mail
* Timer 4 < Overflow Timer On no reply of Trunk
Some help would be appreciated.
mgoegel
Post by mgoegel »
Simply the case of overflow A to B AND B to A shows an loop which is not allowed.
No chance to get this working.
knightr1der
Post by knightr1der »
JHades,
You are going to have to use the magical 'Ghost Z'.
Call to A >> Ghost A (set supervised by user B) >> Voicemail
vice versa
Call to B >> Ghost B (set supervised by user A) >> Voicemail
Voila 8)
Good description knightr1der: "magic Ghost Z". Nothing more true than that.
knightr1der
tot3nkopf wrote:Good description knightr1der: "magic Ghost Z". Nothing more true than that.
Hey tot3, if it wasn't for the ghost (z) - I'd be dead :lol:
OK - on a more serious note JHades, please try and post messages under the appropriate heading. If you're unsure, stick it under MISC. I think its the least we owe to FRANK for setting this thing up for us :D
Return to “MAIN”
