AHL Simulator program
siti
Post by siti »
Hi Friends
Does anyone have a AHL Simulator program which I can use for testing AHL?
I got it but its not working fine.
Siti
There is no lift to success.You have to take the stairs - one at a time.
ibuza
Re: AHL Simulator program
Post by ibuza »
siti wrote:Does anyone have a AHL Simulator program which I can use for testing AHL?
Does the one you got look like this?
It has it's problems because it was written some time ago and the AHL protocol changed a bit since then. But it covers all the basic stuff.
Only real problem: It is only for serial connection and not for the IP link.
siti
Post by siti »
No. The one I have looks different. But no worries, I managed to get another copy of the simulator. I will put it in the paste bin. The only thing that needs to be done on your machine before you get this application working is to change the language settings to French and do a reboot on the machine.
Siti
msmuch
Post by msmuch »
Dear Siti,
I need this AHL simulator, please share it at Pastebin...
siti
Post by siti »
I have posted it in the paste bin. You should find it there.
ibuza
Post by ibuza »
siti wrote:I have posted it in the paste bin. You should find it there.
Thank you. I will test it.
wim146
Post by wim146 »
I have one for serial and IP connections; if still interested?
AHL Simulator V4.5 - Alcatel 2004
Shoot :D
siti
Post by siti »
Yes, I am still interested for the serial connection.
bouncer_ie
Post by bouncer_ie »
V 4.5 posted again in pastebin
Return to “Hotel / Hospital”
