Does someone have some Documentation about how to migrate all the application of OTUC 5.1 server to an ICS 8400?
How can I move all the users?
Thank you very much, I'm kind of new in Alcatel's matters...
Migration from OTUC 5.1 to OTUC 8400 ICS
Re: Migration from OTUC 5.1 to OTUC 8400 ICS
Check the documentation my friend, it is detailed very well on there from exact versions to last versions. The details are on the release notes on BPWS.
balfaroarg
Thank you for your answer.
I've looked on BPWS and there are some documents about "What's new in release 6.x" but there's nothing about how to move all user's data into the new infrastructure. I'm trying to:
- find something to automatically install the new functionalities of My Instant Communicator and deactivate the old services (Softphone 4980, etc) of many many users machines...GPO or something like that
- migrate the 4635 vocal messages to the new ICS structure minimizing the damage and the reconfiguration for the final user
When you download the DVD there is also a PDF, read it carefully and will show you step by step how to do it
macdee
Hi Balfaroag,
Did you manage to get the documentation and perform the upgrade?
How did the install go? I'm upgrading from 5.1 to 6.5 but when I restore the database onto the fresh build many of the services (which would start before) no longer start. I've got a call logged with Alcatel but I've not had an update yet.
Hope to speak to you soon.
Many thanks,
Geoff.
Many thanks,
Geoff.
