Routing based on CLI
thanzeel
Post by thanzeel »
hi all,
I have a call centre system running with Rel 8.0. The customer has a requirement. It is that when international calls starting with 00 comes to the PABX system, they want to know if such calls can be routed to a particular location such as an extension or RSI. But how can we do that. I know if we want to route the calls of a particular phone number we can do through the speed dial. but they want is any number starting with 00 should be routed. How can we do this?
Please help me on this topic..
Hoping for your earliest response
Thanzeel
patmul39
Re: Routing based on CLI
Post by patmul39 »
You can do this using ACR (or Skill based routing).
sadim
Post by sadim »
Or you can use "call filtering routing" OXE facility. No license need.
thanzeel
Post by thanzeel »
but call filtering routing is for complete phone numbers rigth... not for the first two digits right..
sadim
Post by sadim »
Wrong
thanzeel
Post by thanzeel »
so u meant to say... if i just put the starting digits, i can route it to the designated route point??
sadim
Post by sadim »
Yes, thats true.
Return to “ON SITE TROUBLES”
