HELP - TSAPI Premium Server installation problem.
milenski
Post by milenski »
Hello guys,
I am trying to install TSAPI premium server with OXE R9.1 with laboratory OPS. Unfortunately I can't get it to work..
Here is what I do:
1. Installed a virtual machine with a fresh installation of windows 2003 R2 sp2 enterprise edition
2. Downloaded from BPWS installation atchive and extracted the installation files to: C:\CD1_Alcatel_TSAPI_Premium_Server 6.4.7_RunTime\cdrom
3. Read all available documentation and installed all the 3 applications automatically.
4. Configured all according to the documentation
5. Made test: Programs -> Alcatel OmniPCX TSA -> Maintenance -> TSA_maintenance.
Test result:
Usage: [hostname]
Trying connect: localhost 3595
Connection with localhost , port 3595 is OK
You can give arguments -xxx-yyy in command-line, forwarded to main_tsa!
Local commands:
>> filename nb_files size_file to record in local files
write set_client: nbe=
Press return♥
If i enter 505 i get:
Press return♥505
11h25:33.123 MenuMsgStdin 505
Config servers is not ok!
Version: 3.560.31_0
Args : 3595 / @
Obviosly - I have some problem with my configuration... I am using laboratory license.
Oxe is version 9.1
milenski
Re: HELP - TSAPI Premium Server installation problem.
Post by milenski »
Anyone?
Return to “TSAPI”
