No audio in a direction between SIP Phone and UA phone
jpissot
Post by jpissot »
I have a OXE R9.0 H1.301.28B with two appliance. There are a Crystal Shelf with INTIPB and a MG shelf with GD-2.
Appliances, INTIPB, GD and ipphone are in the domain 1. Intra = without compression, extra = default compression.
I have 9 SIP phone (Siemens Gigaset A580).
They can call exterior. In internal, they can can call ipphone and the UA and Z phones behind the MG shelf.
By cons, when they calls phones connected to the Crystal Shelf, they don't hear their interlocutor. But their interlocutors hears them.
The SIP phone are not on the same LAN that CS, INTIPB, GD. I try also with a lan @, the problem is similary.
I don't understand knowing the GD and INTIPB are affected to the same domain.
Thanks for your helps.
Konstantinos.E
Re: No audio in a direction between SIP Phone and UA phone
Post by Konstantinos.E »
hi
if you have all equipment in the domain 1 so u dont use copression(g711). did you try to put the intipb to a different domain and play with codecs?
the sip phone what codec uses?
Alca_holic
MrAnMo
Post by MrAnMo »
If the SIP phone is dialing out. Is that call going through the gd -> pra or through the int-ip -> pra
Could it be that the gateway of the int-ip card don´t have a route to the ip subnetwork from the sip phones?
jpissot
Post by jpissot »
Ths sip phones, the GD cards, the INTIP cards and CS are on the same LAN.
jpissot wrote:Ths sip phones, the GD cards, the INTIP cards and CS are on the same LAN.
One way voice is a clear indicator of a network problem (usually routing of the RTP stream; but can be a firewall also).
jpissot
Post by jpissot »
I have tested at my lab. I use only a switch and I have also the problem.
jpissot
Post by jpissot »
If someone have an idea....
Why I have no audio with my cristal mediagateway???
Thank you.
alex
Post by alex »
jpissot wrote:If someone have an idea....
Use port mirroring on a switch and take wireshark trace of such a call.
Check which addresses is used for RTP and are they really reachable by both parties.
jpissot
Post by jpissot »
I have already made traces.
Communication with UA MG : GD @ and SIP Phone @ . 2 RTP flux
Communication with UA cristal INTIP @ and SIP phone @ but no reverse rtp flux.
Adresses are reachable by both parties.
Includes wireshark traces.
Thank you for your help!!!
jpissot
Post by jpissot »
Wireshark Traces can be downloaded at this link :
http://dl.free.fr/gs1D5Edht
Return to “SIP”
