SIP 407
pixel
SIP 407
Post by pixel »
I have following problem to call accross a SIP Trunk between OXE/ASTERSIK.
All call from OXE to Asterisk are rejected, see under error code
<--- Transmitting (NAT) to 192.168.40.254:5060 --->
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.168.40.254:5060;branch=z9hG4bKc5c86bfd095bb9c6343f4a6994a3d
From: "LABO" <sip:3222@192.168.40.254:5060;user=phone>;tag=6552d80fe0b86f56bfbdb
To: <sip:100@192.168.40.15;user=phone>;tag=as1ba85b2d
Call-ID: 4e95c240ac8b550f2c9337a8399229fc@192.168.1.10
CSeq: 370021654 INVITE
User-Agent: Asterisk PBX 1.6.0.9-samy-r27
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces, timer
Proxy-Authenticate: Digest algorithm=MD5, realm="voipeverywhere", nonce="24ed6dc
Content-Length: 0
SIP/2.0 403 Forbidden (Bad auth)
Via: SIP/2.0/UDP 192.168.40.254:5060;branch=z9hG4bKa33e8d5a753afb2a198ca38e0c77a
CSeq: 370021655 INVITE
Content-Length: 0
See under the conf from OXE
Proxy:
Minimal Authentication Method: Digest
Authentication realm : voipeverywhere (same realm on Trixbox)
External Gateway:
Outgoing realm : vopieverywhere (same realm on Trixbox)
Outigoing/incoming username : oxetrixbox (same username on Trixbox)
Outigoing/incoming password : 11111 (same password on Trixbox)
I don't know if the problem is from Trixbox or a false configuration on OXE.
The incoming call from Trixbox to OXE works fine, the problem is for outgoing call.
Thank.
Return to “SIP”
