Minimum requirement for release 10.0
Xero
Post by Xero »
hi,
I am going to migrate my OXE from Release 6.0 to Release 10.0 and i am not going to use the same CPU 6...i want to know the minimum hard disk and RAM requirements for release 10.0, is there any document for this information??
murraya
Re: Minimum requirement for release 10.0
Post by murraya »
hi, max ram on cpu6 is 128Mb and max harddrive is 80GB. hard drives are only formated to 80 if the disk is larger.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Xero
Post by Xero »
thanks murraya...u mean 128 SD RAM??? not more than that?
murraya
Post by murraya »
yep, no need for any bigger than 128 SD.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Dribbling-vole
Post by Dribbling-vole »
sounds like you know what you are talking about murraya.
how much physical room does it need also ?
I have an r10.0 DVD and it doesn't seem to fit on a CPU6 with 128 of ram, I have even tried spanning it across floppy disks but it still doesn't fit and it took 4 1/2 days of changing floppies to find that out. please help.
murraya
Post by murraya »
hi, you don't install the version via the floppy. check the DVD and you should find an application called "PC installer". install that to a PC and the use it to serve the CPU 6 via ethernet.
Try the search in this forum for information on installing software.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Dribbling-vole
Thanks Murraya. I still have the problem because the slotting for a DVD I can not find in the chassis. Can I solder a CD player to the backplane. I am careful.
(sorry for my english speaking as it is not my bestest language)
Konstantinos.E
Post by Konstantinos.E »
hi
There is an section with Documentation! is not posible to tell you everything how to install it..with alcatel products you have to study..
Alca_holic
murraya
Post by murraya »
I was almost going to give directions on soldering DVD to backplan :)
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
Dribbling-vole
so, if I can't get it off the DVD and you won't tell me how to connect the player to the chassis, is it possible to type it in ? I used to do that with my Commodore PET and VIC 20 for moon lander and well it worked.
Return to “Shelf”
