No beeping on Multiline
gundam
Post by gundam »
I am working on an issue release 4.1 (d1.305) that been running for 4 years.
Last week, not all but some, Users suddenly unable to hear a beep on second incomming call on the multilline if he/she is on the first miltiline.
Rebuilding the User did not resolve the issue.
Anyone have any idea? If not I am going to reboot the PCX to see if that will fix the issue.
H-MAN
Post by H-MAN »
Try resetting "Protected against Multiline Rringing" in the phone features Cos. Set it to 1 accept and the back to 0. Maybe this helps.
Shit happens!!
gundam
Post by gundam »
Will check on it now.
User/ Dynamic state user - Busy camp-on, box must be checked. Customer dial suffix "camp-on control" or soft key "CampOn" on 4035 set was pressed.
alcateloxe
Post by alcateloxe »
Hi!
Probably should check if it is activated the next parameter in the Phone Facilities Cateogry
mgr/Categories/Phone Facilities Category/
Ringing tone In Handset: [0 or 1]
Set it to 1 if the user wants to hear the ringing tone in the handset for the second incoming call
Set it to 0 if the user doesn't want to hear the ringing tone in the handset
Roger
patmul39
Beeps
Post by patmul39 »
Go to the Phone Facilities (of the users/s) and set the parameter Protected against beeps to 0. If it is set to 1 All beeps are stopped; if you want to disallow beeps on external calls there is another parameter to check: Beeps on external calls
gundam
Post by gundam »
issue resolved, thanks for all the input.
It took a double bascul to fix the issue.
Return to “ON SITE TROUBLES”
