Problem with set supervision
alexeik
Post by alexeik »
I created set supervision keys with the option " short ring without overinging" on 4 different sets to see the incoming calls of each phone. all users are configured exact identical. but only for calls for one user it is working correct. calls to the 3 other users are presented as if the keys are configured with the option "no ring". the key shows that the phone is ringing, but no ring and number shown in the displays. There are several of these groups working fine. I´ve recreated the keys, i´ve deleted the whole user and created them again... no change...
are there any limitations for supervion keys with short ring??
Release of the oxe is Rel 6.1 / f250226
Eliott_DUP
Re: Problem with set supervision
Post by Eliott_DUP »
I remember there was a limit of 20 supervisons per user.
That's the only restriction in my mind for the moment.
Eliott_DUP
I can't edit my posting here :(
Supervisions per Node: 15.000
Supervision keys per set: Limited by number of keys on set
Supervisors for one DN: 20
Supervised sets: No limit
But you could check your tables using the command: multitool CHECK REPAIR
Eliott wrote:I can't edit my posting here :(
Why? an error? A limitation?
knightr1der
Post by knightr1der »
Appears to be a limitation Señor Cav.
I've just looked at a post I made earlier today and there is no 'EDIT' option like there used to be :(
Muchas gracias caballero, lol.
I'll check it.
By the way, is limitation bad written?
Sorry guys, it's fixed now, you should be able to edit your own posts.
knightr1der
no - limitation is not badly written. But the question should be "Is 'limitation' written badly (or incorrectly)"? LOL
tenga un buen fin de semana mi amigo :wink:
ok thanks :)
Returning to the main subject of this post, any news alexeik with Eliott ideas?
alexeik
Post by alexeik »
thanks for the idea, i will try it...
... and i wondered why so many replys^^
Return to “Users”
