Who release call first?
thkim81
Post by thkim81 »
Hi~
I testing the call release.
so When I calling the IP phone with mobil phone.
I will release and then IP phone release .
How do I know Who release call first ?
t3 log is not indicated.
I cann't analays in mtracer.
Who know about this ?
murraya
Re: Who release call first?
Post by murraya »
you will see in t3 trace the release direction. please post trace and we'll see if anyone can help you.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
thkim81
Post by thkim81 »
when i testing the call,
case >
when calling the IP phone to mobile phone
1. When IP touch phone first off phone
2. When mobile phone first off phone
2 cases is same result when i testing.
Eliott
Post by Eliott »
1st: <<<< message sent : DISCONNECT [45] Call ref : 00 09
2nd: <<<< message sent : DISCONNECT [45] Call ref : 00 0d
In both cases the OXE releases the call.
I think you made a mistake when testing.
PS: Is Subadressing used on this trunk?
| (450328:000014) Concatenated-Physical-Event :
| long: 35  desti: 0  source: 0  cryst: 2  cpl: 6  us: 0  term: 0  type a5
| tei: 0  >>>>  message received : CONNECT (07)  Call ref :  80 09
| IE:[4c] CONNECTED_NUMBER (l=13)  ->  21  83  Num : 01087213549
| IE:[4d] CONNECTED_SAD (l=0)  <<<<<<<<<<
| (450328:000015) 1399: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 26  desti: 0  source: 15  cryst: 2  cpl: 6  us: 8  term: 0  type a5
| tei: 0  <<<<  message sent : STATUS [7d]    Call ref :  00 09
| IE:[08] CAUSE (l=3) 81 e4 4d -> [e4] INVALID INFORMATION ELEMENT CONTENTS
| IE:[14] CALL_STATE (l=1) 0a
INVALID INFORMATION ELEMENT CONTENTS complains about the 4d => Try to ignore it using mgr > System > React rec. state message flags.
thkim81
Post by thkim81 »
thanks Eliott.
so, If I testing normal, I know Who release the first off phone ?
otherwise case, When I testing the calling from mobile to IP phone, same result .
first, When mobile phone is hanu up.
second when IP phone is hang up.
both of result is first off mobile phone.
Return to “Trunk Groups”
