is it possible to break passwords of su and swinst?
penny
i know only mtcl password. is it possible to break passwords of su and swinst? is there any way or contact alcatel?
Re: is it possible to break passwords of su and swinst?
Google is the answer.penny wrote:i know only mtcl password. is it possible to break passwords of su and swinst? is there any way or contact alcatel?
If you search for words you mentioned you'll get hella lot of sites with all passwords.
But good practice is to change all default passwords in a system.
if it is Ux version of 4400 & you can get ftp access there is a backdoor way.
You can ftp to the system using the account name 'halt' passwd 'tlah' (if it hasen't been changed already) the rename the .profile to anything else. Then login as halt & you will have uid of 0, now you can change the passwds
la_toupie
la_toupie
- frank
I just wrote an article, with a document on how to recover root password.
Once you get this one, you can setup any user passwords:
viewtopic.php?t=802
viewtopic.php?t=802
