Hi brots,
I just installed one syslog server for one Iptouch in mode test. I see the messages in syslog ¿ Anyone know the meaning of messages ua3? ¿There is anyway to decode this messages?.
Thanks for your replies. Bes regards.
EVENTS SYSLOG
Re: EVENTS SYSLOG
Can you post a sample?
dryhouse
Re: EVENTS SYSLOG
ok..
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 04 00 29 11 F6 F0"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.680 AUDIO : audiodecode_noeVoiceMode : VM=11, RXG=-10, TXG=-16"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 02 00 3F 01"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.680 AUDIO : audiodecode_mute: mute disable"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 03 00 3D 01 D6"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.680 AUDIO : audiodecode_sidetone : MODE=1, LEVEL=-42"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 AUDIO : audiodecode_noeVoiceMode : VM=11, RXG=-10, TXG=-16"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 14 00 13 0A 15 10 31 42 28 46 A4 BC F4 17 D9 06 43 2A F6 6D 5C C3"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 41 00 13 01 02 00 02 7F 02 01 04 AC 1A 52 1B 02 02 1F 40 03 01 B8 04 01 00 05 01 14 06 01 01 07 01 00 0A 01 01 0B 01 01 31 01 00 0D 01 01 15 01 00 50 10 51 3B 1A 68 11 E8 1D EA 1E 20 CC 91 EF FB A3 55"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 UA3 : message_sign_verif signature OK?: 1 (TRUE 1, FALSE 0)"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 arpresolve 172.26.80.254 OK"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 AUDIO : open session 0"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 BCM : RTPT - RTPT: sockets rtp=14 rtcp=15"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 AUDIO : ----- rtpCmd_openSession: Session 0 Opened (handle=0) ------"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 001-08:26:00.690 AUDIO : eptStream_create: Stream 0 started"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 0E 00 15 02 08 8A 00 08 44 52 59 48 4F 55 53 45"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 0B 00 15 02 97 20 20 36 02 81 F8 37 00"
19 Jan 2012 16:27:02 CET,"<15> 16:26:53 ua3 : S 08 00 15 02 89 20 70 3E 01 00"
do you think??
Thanks. regards..
do you think??
Thanks. regards..
Re: EVENTS SYSLOG
You don't think that every 2nd line is the decode of the prevoius one?
dryhouse
Re: EVENTS SYSLOG
I don´t think. i have many lines without 2nd line with decode. For example:
20 Jan 2012 09:17:22 CET,"<15> 09:17:17 ua3 : R 04 00 15 04 02 35"
20 Jan 2012 09:17:22 CET,"<15> 09:17:17 ua3 : S 08 00 15 02 84 20 40 37 01 35"
20 Jan 2012 09:17:22 CET,"<15> 09:17:17 ua3 : R 04 00 15 04 02 36"
20 Jan 2012 09:17:22 CET,"<15> 09:17:17 ua3 : S 08 00 15 02 84 20 40 37 01 36"
20 Jan 2012 09:17:22 CET,"<15> 09:17:18 ua3 : R 04 00 15 04 02 38"
20 Jan 2012 09:17:22 CET,"<15> 09:17:18 ua3 : S 08 00 15 02 84 20 40 37 01 38"
20 Jan 2012 09:17:22 CET,"<15> 09:17:18 ua3 : R 04 00 15 04 02 39"
20 Jan 2012 09:17:22 CET,"<15> 09:17:18 ua3 : S 08 00 15 02 84 20 40 37 01 39"
20 Jan 2012 09:17:22 CET,"<15> 09:17:18 ua3 : R 04 00 15 04 02 33"
20 Jan 2012 09:17:22 CET,"<15> 09:17:18 ua3 : S 08 00 15 02 84 20 40 37 01 33"
20 Jan 2012 09:17:22 CET,"<15> 09:17:19 ua3 : R 04 00 15 04 02 34"
20 Jan 2012 09:17:22 CET,"<15> 09:17:19 ua3 : S 08 00 15 02 84 20 40 37 01 34"
20 Jan 2012 09:17:22 CET,"<15> 09:17:20 ua3 : R 04 00 15 04 02 35"
20 Jan 2012 09:17:22 CET,"<15> 09:17:20 ua3 : S 08 00 15 02 84 20 40 37 01 35"
20 Jan 2012 09:17:22 CET,"<15> 09:17:20 ua3 : R 04 00 15 04 02 36"
20 Jan 2012 09:17:22 CET,"<15> 09:17:20 ua3 : S 08 00 15 02 84 20 40 37 01 36"
20 Jan 2012 09:17:22 CET,"<15> 09:17:21 ua3 : R 04 00 15 04 02 39"
20 Jan 2012 09:17:22 CET,"<15> 09:17:21 ua3 : S 08 00 15 02 84 20 40 37 01 39"
20 Jan 2012 09:17:42 CET,"<15> 09:17:22 ua3 : R 04 00 15 04 02 38"
20 Jan 2012 09:17:42 CET,"<15> 09:17:22 ua3 : S 08 00 15 02 84 20 40 37 01 38"
20 Jan 2012 09:17:42 CET,"<15> 09:17:22 ua3 : R 04 00 15 04 02 35"
20 Jan 2012 09:17:42 CET,"<15> 09:17:22 ua3 : S 08 00 15 02 84 20 40 37 01 35"
20 Jan 2012 09:17:42 CET,"<15> 09:17:23 ua3 : R 04 00 15 04 02 33"
universal alcatel ??
Thanks. Regards.
Thanks. Regards.
Re: EVENTS SYSLOG
Mmh. The protocol is not free. So I think there is no way.
There was a plugin for Wireshark which can decode the signalling messages - but it's not free, too.
