Error accessing log files
davidpcm
Post by davidpcm »
Just 2 weeks ago, our company have upgrade our switch to 10K. It was running fine till now while I was accessing the log, I got the below error messages. Anyone can help on this? Thanks!
ERROR: Incomplete command
xxxx> show log swlog
ERROR: display error (incorrect index = 0)
xxxx> show swlog
xxxx> show log swlog slot 1
xxxx> show system
System:
Description: Alcatel-Lucent OS10K 7.1.1.1722.R01 Service Release, October 14, 2011.,
Object ID: 1.3.6.1.4.1.6486.801.1.1.2.1.9.1.1,
Up Time: 20 days 7 hours 53 minutes and 37 seconds,
Contact: xxxx,
Services: 78,
Date & Time: MON MAR 12 2012 08:43:10 (ZP8)
Flash Space:
Primary CMM:
Available (bytes): 1681559552,
Comments : None
bitbin
Re: Error accessing log files
Post by bitbin »
what does output of "show swlog" look like? for me it shows as below, through I am running a more recent version of code (7.2.1.323.R02)
good chance that you can resolve this by doing "swlog disable" and then "swlog enable"
RGH-25-10K>> show swlog
Operational Status                 : Running,
File Size per file                 : 125K bytes,
Log Device                         : console flash,
Syslog FacilityID                  : local0(16),
Remote command-log                 : Disabled,
Hash Table entries age limit       : 60 seconds,
Switch Log Preamble                : Enabled,
Switch Log Debug                   : Disabled,
Switch Log Duplicate Detection     : Enabled,
Console Display Level              : info,
davidpcm
Post by davidpcm »
Hi bitbin.
Thanks for the help. Btw, got reply from Alu support, it been fixed and release on AOS version as mentioned.
Regarding the 'show log swlog no output' issue, its already been fixed and merged in all the releases 7.1.1.R01, 7.2.1.R02, 7.3.1.R01. All these fixes will be merged in the regression tested code releases which were yet to be released. We will provide you the ETA for the next regression tested codes with the aforementioned code fix.
Return to “OmniSwitch 10k”
