Pb Address of tunnel
la_toupie
Post by la_toupie »
Hi all,
I've validate the x25 in the netadmin to create a hybrid link. The problem is that I've forgottent to change the address of the tunnel by default 172.30.253.X.
I've changed after this address in 170.30.253.X to be compatible with the rest of my network.
And now, my hybrid link don't work and in X25->Node of Networks; all tunnels have as address 172.30.253.X and not 170.30.253.X.
Shutdown is done but without effect...
An idea ?
la_toupie
Post by la_toupie »
For information,
I have done a new netadmin without X25 ->Shutdown
I valide the X25 and I change my tunel's address ->Shutdown.
And now, in X25->Nodes of Networks; I've the good tunnel' address.
Only now, my hybrid link don't run corectly; i'ts up with 'hybvisu' but I don't use VPN but oveflow private to public :cry:
I've checked all my gestion but I don't see the problem
I think you cannot change by hand the X25 tunnel. It never worked when I did it. I also had the same trouble that you are descripting. The only way I fixed it was to redo a netadmin , recreate the tunnel, and redo the hybri links and VPN from scartch.
la_toupie
Post by la_toupie »
In fact, I think that I changed the addresse of my tunnel after the shutdown.
I must do a shutsdown after the change of this address. Now, it works :D
Return to “X25”
